JD300B hose from Hydraulic filter to Transmission Help?
   / JD300B hose from Hydraulic filter to Transmission Help? #1
Axl2011
Member
East Liverpool, Ohio
John Deere 300B
Where could I find this hose, or what could i use? I can not seem to find low pressure hydraulic lines and I do not want to leave my system drained for days.
   / JD300B hose from Hydraulic filter to Transmission Help? #2
McMaster Carr has 3/4" id low pressure hyd. hose..
McMaster-Carr
Adding your location to your profile will help direct you to possible local findings.
:welcome: to TBN
I guess that would be true. Lol I live in East Liverpool, Ohio (I will go update now)
   / JD300B hose from Hydraulic filter to Transmission Help? #4
Try NAPA or your local JD dealer.
I went to NAPA the guy was unsure about if the hose would handle hydraulic fluid.. The dealer I originally went to said they don't have hoses, So I am calling around again today. If no luck I will order from the site above.
My main concern is that I am unsure if leaving the system without fluid for days would cause harm or not?
   / JD300B hose from Hydraulic filter to Transmission Help? #6
Likely not.. as long as you don't start it up and try to run it (figure you know that already).
Yeah. I did end up finding a place nearby that does make them so I am going there to get one! Thank you for that site also!!
May be a stupid question but are you to bleed air out of hydraulic lines? The backhoe still moves kind of slow after changing filters and the milky hydraulic fluid to fresh fluid.
Thanks again!
   / JD300B hose from Hydraulic filter to Transmission Help? #9
Air in hyd hoses/cylinders will bleed out when cylinders are cycled through normal operation. I suggest to check stand-by pressure which should be 2250 psi.
How would I check stand-by pressure? Sorry if I sound stupid. New to all this and learning. I appreciate all the help from everyone!
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2024 CATERPILLAR 299D3 SKID STEER (A51242)
2024 CATERPILLAR...
6 Trench attachment (A50322)
6 Trench...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
