Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon!
   / Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon! #11
Re: Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon!
Second day and another 3 hours added:
-Removed the backhoe: pretty easy, but lots of hydraulic fluid came out of the connectors (maybe a 1/8-1/4 cup). Need to have rags handy. Even without the backhoe, the ride still feels bumpier/rougher than my NH - maybe the Rimguard/beet juice...?
-Removed PTO cover and installed 84" finish mower; mowed a couple acres. Somehow, the mower feels "closer"/"tighter" to the back end. PTO selector switch to "auto" and pushed the button to engage. Pleasant experience being cool from a/c and listening to my favorite band Fountains of Wayne connected via Bluetooth to the stereo.
-Used the cruise control for mowing - the push-button is a slow to respond when turning off (have to hold it more than just a "punch"). Same with the "cruise control speed switch" - have to hold it more than a "tick" to get a change.
-No temp gauge - it's an idiot light
-The owner's manuals - all of them backhoe, tractor, loader - are marginal translations. Often, I have to read something several times to understand what is actually meant. Here is an exact quote from the Draft Control Lever: "...By mounting the lever forward, the depth increase.<sic>" The Introduction & Description says the engine is "manufactured by Perkins".
-Removed the grapple to try on my old heavy-duty bucket - again, I was surprised by the amount of fluid that came out of connectors. Reinstalled it, but had to relieve hydraulic pressure in order to reconnect by turning the ignition on (but not starting engine) and cycling the 3rd function. Sight-lines make it very difficult to see where the SSL/QA plates on the loader align with the bucket, grapple, and pallet forks. With the grapple's hoses, have to be extra careful since the lock arms have to be vertical when unlocked (can snag hoses).
-Load sensing button would not stay on - pushed it, but indicator light went out after a second or two. I'd be interested to know if anyone else has experience with this anti-stall feature.
Still loving the new tool. The grandkids and I power-washed the New Holland to prepare it for sale. Looks really good. Someone will end up with a nice, well-loved, used tractor.
I found the same issue with the hydraulics when disconnecting and connecting the third function up front for the grapple. Had to do the same thing you did to relieve the pressure. And it does lose a lot of fluid. I put some grey duct tape on my bucket and the grapple to help line up the skid steer plates until I get better at it. The hose do get in the way for the grapple and once I almost grabbed it pretty badly. The tool box should go on with no problems. I have to get you a picture in the morning. This cold is taking a lot more out of me than I’d like to admit.
Enjoy the tractor and nice write ups.
.Enjoy the tractor and nice write ups.
Thanks, Gunny! Backatcha!
Feel better, man!
   / Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon! #13
Do you have the auto-throttle turned on? I'd have to check to make sure, but I think I remember that the load-sense only works with auto-throttle disengaged (which I think makes sense).
   / Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon! #14
My 55HC pretty much rides like a buckin bronco at speed on smooth surfaces. Ok not that bad but it痴 very bouncy in the rear. Since the tires are at the recommended pressures, I chalked it up to all that fluid sloshing around, or the tires are just not meant to be balanced all that great.
   / Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon! #15
Feel better, man!
The tool box, if you can call it that, sits just to the right of the washer fluid reservoir and above your rear remotes. If you need a photo of the mounting bracket, just let me know.
   / Nobody has "a case of the Mondays" at The Farm - RK55HC delivered this afternoon! #16
Just confirmed on mine this afternoon. If you have the auto-throttle on the load-sense will light for a few seconds then turn off.
Ah...that explains it: I got the third set of remotes, which sits on top of the other two. They might have had to take off the toolbox to make room. I'll confirm when I get some seat time later today. Thanks for the picture!
Thanks for the update. Didn't have time to check yesterday - took 75% of the grandbabies to Hershey Park. Since I run auto-throttle almost all the time, that is likely it. These little tid-bits would be nice if they were published in the owner's manual (assuming it was grammatically correct...)
That was it: auto-throttle on disables load-sense. Thanks!
The third set of remotes makes lining up the bracket's holes for the screws impossible - about a quarter-inch too high.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A55745)
2013 XLR...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
