TODAYS SEAT TIME
   / TODAYS SEAT TIME #9,942
Hey Oldpath, I needed to get a tractor out of the loft of my barn, So I set a couple ramps on my pallet forks/grapple and rolled the tractor on the ramps, then setting it on the ground outside...
That's another thing a dedicated grapple won't do!! ha ha ha
SR
   / TODAYS SEAT TIME #9,943
Fertilizing, the only have 600kg bags so loading by bucket it is.... IMG_20190729_092415.jpgIMG_20190729_094554.jpgIMG_20190729_114245.jpgIMG_20190729_114222.jpg
   / TODAYS SEAT TIME #9,944
   / TODAYS SEAT TIME #9,945
It's trash hopefully the recyclers manage it.
It would be nice to have an alternative use for all of it.
Not much you can use it for after its unwrapped, here you pay a recycling fee when you buy new plastic and then you deliver it for free to recycling, but it took some years before that system was in place. Hay are not much used so almost all is wrapped so it's quite many tons of plastic.
But I'm not living in the US.
   / TODAYS SEAT TIME #9,946
SR
Awesome, but wheres the mower deck? looks like a 50 year old Wheel Horse or something........
I'm always a fan of one tool does all. I could do the same at my 8' high loft and was going to with my riding mower but my forks at best is 7' level. So I button up my small shed as good as I could to keep mice out and put it there, just one more reason for two size tractors.
   / TODAYS SEAT TIME #9,947
Hopefully it's not going into landfills but recycled into more plastic wrapping, I also see sailboats and RVs wrapped in that stuff.
   / TODAYS SEAT TIME #9,948
Once it goes into the dumpster I have no clue,
I'll agree that hopefully it goes no wheres near a landfill.
It is quite often a bit dirty so i have no clue as to the recycleability of it,
but I'm a bit old school if it can't be recycled I hope that it at least goes to a well built and designed burn plant, as the btu value of plastic is huge.
If I was younger I would be awfully tempted to get a pellet maker and use plastic and garbage brush and weeds to make heating pellets,
then a good forced air heat unit.
We have enough waste plastic to heat a couple of farms and households, between bale wrap, ag bags, and all the bagged seeds and other products purchased through out the year.
   / TODAYS SEAT TIME #9,949
Big boy farmers here (and every place else I've seen) use a bale "grabber" not a grapple, different tool completely, OR they use an end loader with a bale fork.
Depending on the definition of "tinker toy tractor" you are right, but that isn't how I define one, and I have both. AND just for the record, we hay with bigger tractors than I most often show, too...
Quick example: I have a 6' rotavator, I've shown it many times. I also have a 30hp Deutz "farm" tractor. Over the years, I've put 500 hours on that Deutz custom rotavating with that rotavator.
At one time I bought a 30hp Kubota compact tractor, it seemed nice enough and after a time I decided to try the 6' rotavator on it. Worked OK for smaller gardens, but there's NO WAY I could take it on field jobs, it just didn't have enough nuts to be used for hours and hours on end in field conditions on jobs.
There's the classic difference between a farm tractor and a tinker toy compact tractor!!! They make them with lots of hp, but they just can't compete with an equal hp farm tractor for long tern field work or last as long doing that work.
After a few more "things" like that, I sent that Kubota down the road. Would have make a good play farmer tractor though.
I have compact tractors, I just don't try to use them for real farming... lol
SR
Nice load of hay SR.
This year I didn't even hook up my big trailer. Guys I sold to brought their trailers and I loaded them right from the field. Very nice and they have committed to buy from me every year. The second cut might be a different story, none is sold at this point. Should be cutting in about 3 weeks.
   / TODAYS SEAT TIME #9,950
We wrap many of our bales with a bale wrapper as silage bales to get a well wrapped bale requires a good shape bale that hasn't been damaged by the handling prior to wrapping so it can be sealed upwell with the wrap and not allow air in to rot it.
Once it's wrapped it can't be punctured for the same reason;
View attachment 614858 View attachment 614859 View attachment 614860 View attachment 614861
so we use a squeeze grapple designed for round bales
So how many of these wrap bales do you get and where do you put them, in some sort of shed?
International 5088 2wd Cab Tractor (A52128)
International 5088...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
