JasperFrank
Elite Member
- Joined
- Nov 23, 2018
- Messages
- 2,940
- Tractor
- Ford 1220
I'm not sure if I can trust my tire gauges.. One is electronic and the others are the Slide Type. Getting very different readings. The valves spit water, even at 12 oclock. Electronic says 18.5, the sliders just give me 7 or 8 PSI. I can set the air compressor at 20 but it will not fill at that low a setting. I can only hear bubbling if the Compressor is set to 40. Don't like guessing since there are warnings not to go over 38 psi. How do you guys set the psi on Calcium filled tires?
