Popular mythconceptions
   / Popular mythconceptions #371
You should have had Cagney and Lacy on speed dial!
Funniest thing on COPS. They rigged a car to be stolen and had a camera and radio controlled ignition kill and door locks. Before the cops even got to the car, the perp was repeating (practicing) I didn't do it, I didn't do it! As he sat at the wheel of a car he just stole!
   / Popular mythconceptions #372
   / Popular mythconceptions #373
None of You Men here on TBN are "Hen Pecked" !!! ..............................
   / Popular mythconceptions #374
I do not remember being "taught" that but it was commonly known back then (30s-40s)
   / Popular mythconceptions #377
Wires always spark when hot wiring a car and must be drawing huge amounts of current.
Is it even possible to hotwire a modern car?
Bomb makers go by a strict color code, and the blue wire is always the one you cut to disarm it.
All bombs have a digital countdown timer.
   / Popular mythconceptions #378
The most powerful explosives are brightly colored liquids and are kept in see-through containers, often bearing sets of shiny appendages.
People exchanging gunfire indoors can hear each other quite clearly as soon as the shooting stops.
Bad guy boss can absorb magazines-full of ammo and have enough breath to give a two minute speech.
His thug is instantly and permanently disabled after receiving one bullet or a throat punch.
John Wayne.
   / Popular mythconceptions #379
A little cross-over here.
Put your nuts out on the driveway - drive on them - it will remove the husks
To crack your nuts - lay them on a wooden block - ask your wife to whack them with a meat tenderizer
If you wash your nuts to remove the goo - be sure to lay them out to dry or they may rot
   / Popular mythconceptions #380
TBN P!ssing matches are always entertaining and reasonable
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
24' PIN ON EXCAVATOR BUCKET (A52707)
24' PIN ON...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2015 CASE CX300C EXCAVATOR (A52707)
2015 CASE CX300C...
Reel Mower (A55851)
Reel Mower (A55851)
