Error code 008 NX4510
/ Error code 008 NX4510 #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
I may as well tell the whole story here. Last weekend while mowing my fields I had the regen light come on. This is the first time since last September when I had an issue with the throttle lever potentiometer failing on it. I have put about 80 hours on the tractor since then. I always run it above 2000 RPMS at all times so that the motor is not lugging. I ran the regen cycle and it was back to normal. It was working fine until yesterday when I was out mowing the fields again. I ran it for at least 2 hours before it came on. The regen light came on and I ran the regen cycle again. Within an hour the regen light came back on. I ran the regen cycle again. This time it only stayed running good for about 15 minutes. I gave up for the day and drove it home. I ran the regen cycle one more time and this time it only started the cycle and the engine CEL light came on and the regen cycle ended. I pulled the two sensor probes (exhaust sensors I assume). One is in the DPF muffler and the other is under the turbo in the exhaust manifold. They were both covered in soot deposits. I cleaned them up and put them back in. I got my friend's OBD2 monitor and was able to clear the code. Upon starting the tractor up the regen light came on. I tried to run the regen cycle but couldn't because the CEL light came on too quickly. I kept clearing the CEL light and the regen light kept coming back on. All of a sudden I noticed the ERR 008 code on the hour meter. This is the first time that I have ever seen a code show up there. Does anyone know what this code is? I'd like to know before I have to go borrow a trailer and tow this back to the local dealer which is an hour ride away. TIA guys.
/ Error code 008 NX4510 #2
Yeah I used 'start page' search engines and it just exposed a pet peeve of mine.
Other then JD, it seems tractors unlike autos do not have a penchant for divulging OBD codes.
I have a BOCH scanner and tried reading codes on mine and My Wiley does not like BOSCH....lol....
It seems you may have to trailer up to dealer. However a quick call and maybe your dealer can walk you through it.
It may be as simple a clean up of sensors and Key on/off method to reset codes.
Keep us posted.
I've got 375 hours on mine and am prepping tractor and cutter for cutting 10 acres next week about 15 miles from home.
So this may be an anomaly, I get it stuff happens but its good to stay informed.
Have a good weekend.:thumbsup:
I tried the disconnect battery trick. The clear the code, key off and back on. I can even clear the code while running and the light goes off and the blinking regen light comes on for about 5 -6 seconds. Then it goes out and the CEL light comes back on. I even had it to tell me the error code again on the hour meter. There are a few guys on here with a manual that have the codes in it.
/ Error code 008 NX4510 #4
ERR-008 = no signal at Water IN FUEL Input. Bob
Thanks Bob, I'll check that out tonight when I get home from work.
/ Error code 008 NX4510 #6
My brief (and often humbling) time working on vehicles has led me to believe your error code may be a symptom of another issue. I had a CEL on my truck come on that left me stranded across town (1 hour drive to the house). Found it later it was the turbo vane position sensor that had gone out. But....it shared the same circuit as the throttle position sensor, so you had to probe the wires for voltage output to determine which one was the culprite. I'll give you a hint which one it was....the more expensive of the two. :mad:
In other words, I don't know that the WIF sensor is the primary culprit. The ECM may be throwing a code based on odd voltages come from another sensor. Electronics are funny that way. I'd call your dealer and ask them about the REGEN cycles, and also mention you have an error code now. It also wouldn't surprise me that the WIF sensor was disconnected, wire broke off, or wasn't making good contact, and that's the cause of your REGEN cycle issues.
Either way, we'd greatly appreciate your follow up with root cause! :thumbsup:
/ Error code 008 NX4510 #7
I was getting the same 008 code on mine, ended up unplugging the connector at the sensor on the fuel filter and cleaning it.
As for the cel and the regen issues that’s more than likely going to be a complete different issue and you really need to have the codes pulled to see what is going on. Will your friends scanner read them or just let you clear them?
The first couple times the regen light came on was it flashing or steadily lit?
/ Error code 008 NX4510 #8
Not to derail the thread, but this brings up a good series of questions. Are there sub-$200 scanners out there that can read the codes? Any other way to read the codes without a scanner? Can anyone link to a listing of what the codes mean?
Thanks!
/ Error code 008 NX4510 #9
I’ve not found one that will read the codes, all the codes are in the service manual, and it’s a lengthy list.
It was steady light at first. Now it is blinking all the time. I cannot read the codes but can clear them. The reader says there are no codes after scanning again. It is raing here today so checking the wiring will have to wait.
Is there anyone willing to post the codes for these tractors?
/ Error code 008 NX4510 #12
You said the first few times the light came on you tried to do a regen? You do know that if the light comes on steady, that you keep working like normal , just keep the rpms universe 2000 or so, it does the regen automatically. Only time a park regen is required is if the light flashes. As for the codes there are only a few that show on the hour meter, but there are a couple hundred maybe that will show up on a ecm , I have the service manual on another computer I can try and copy the list off of but will be a few days.
/ Error code 008 NX4510 #13
Care to share where you got the electronic copy? Been looking for one for a while now, and the only one I can find is from a questionable site. Still scratching my head about why Kioti doesn't offer an electronic service manual.
/ Error code 008 NX4510 #14
Just to clear up a bit of confusion, the error codes that come up on the intrument panel only indicate "Safety Start Circuit" failures. The CEL Light indicates ECU Errors that have to be read by the KIOTI Diagnostics Program. So...if you see error codes on the instrument panel, there is a fault in the safety start curcuit. CEL Lights indicate engine ECU faults. Completely different systems.
Hope this helps
/ Error code 008 NX4510 #15
Hope this helps
Is there any way to read the ECU error codes without a trip to the dealer?
/ Error code 008 NX4510 #16
Only KIOTI Dealers can read ECU Faults on KIOTI Tractors. The diagnostic system is Proprietary.
/ Error code 008 NX4510 #18
I can see a Right to Repair argument starting here... Not trying to start one.
Yeah can be a sore point because the Green tractor farmers are going through this issue as well. I think TBN had a long thread as well.
So we may be stuck with the system for now.
TO bad all the hackers are busy hacking games and OS, instead of maybe a service of how to read farm equipment.
I see an opportunity here lol.
It has been very informative on the topic of reading CEL codes so thanks for that also.
I was not aware of the auto regen. I know know the difference n the lights. Withot my glasses I never would have seen the difference in the bars. Lesson learned, Thanks
Tonight I did look into this issue. I have a ground on one wire of the switch. Nothing on the other side. I did check my filter for water and it is fine, no water and no water light.
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
Lot of (3) HD Pipe Gates (A66408)
Lot of (3) HD Pipe...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2018 Deere 770G (A64126)
2018 Deere 770G...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
