Kubota Radiator Cap Danger...
/ Kubota Radiator Cap Danger... #11
I must say I was surprised that the pressure built up enough to blow the filler neck, since steam was escaping through the overflow. When the whistle blew, I took the load off the tiller and let the engine run to cool it down. That worked several times until it didn't. Could the overflow tube have gotten clogged?
/ Kubota Radiator Cap Danger... #12
I think it is a case of PSI times square inches = pounds of force. The cap outlet, being smaller in diameter than the top of the filler neck, means that the filler neck in actuality may have more "force" against it than the cap itself. Over time this pressure, no pressure, pressure will take a toll on a solder joint, especially if there is any corrosion attacking the solder joint.
/ Kubota Radiator Cap Danger... #13
If the filler neck was forced off, the solder would have a dull torn look. If the temperature was hot enough to melt the solder, it would be shiny. I remember reading about kubota radiators with plastic tanks melting right where the upper hose meets it. Why is the coolant getting that hot?
/ Kubota Radiator Cap Danger... #14
Who heats coffee to the boiling point?
I don't heat coffee to the boiling point but I like hot coffee and I heat the water to that point. I always nuke take out coffee......M
/ Kubota Radiator Cap Danger... #15
It was shiny.
My question, too.
/ Kubota Radiator Cap Danger... #16
Water in a radiator cannot get hot enough to melt solder. You will not ever see that. If the radiator was plastic then some crack around the neck below the radiator cap developed and finally blew. If it was metal then it was a very RARE blow off of a neck on a radiator. Many things had to conspire and be wrong at the same time. The cap shold have released the pressure LONG before the neck was damaged. Hoses should have blown before the neck was damaged. etc etc. This is an odd one at best. Probably more to the story of course & no way to know ...
/ Kubota Radiator Cap Danger... #17
Several things to report:
1. The mechanic who works on my car told me how to drain the radiator - drain plug at the bottom. (Of course, the drain plug fell into the jar, but it won't be to hard to get it out.)
2. He told me about 4 bolts to remove the radiator - turns out there are only two needed to remove it, but of course, all the shrouding needed to be removed first, as well as the hoses, one of which had to be cut.
3. Successfully removed the radiator. :)
4. He told me about a nearby radiator repair shop where I'll take it within the next couple of days.
5. Although the place where the filler neck came off the radiator was shiny yesterday, today it's dull. Must have oxidized overnight. It's been rainy.
6. JWR, I agree that it's very strange that it got hot enough to melt the solder. There must have still been water in the radiator when it blew because there was a huge cloud of steam when it did blow. Could be that the radiator cap didn't release pressure properly, but just before it blew, the pressure relief tube was whistling, releasing steam. So perhaps the connection between the neck and radiator was weak. I don't remember how long ago the radiator was replaced, but i'm sure it was less than 10 years. Perhaps the radiator repair guy will have some ideas.
Thank you everyone for your thoughts and comments.
/ Kubota Radiator Cap Danger... #18
/ Kubota Radiator Cap Danger... #19
I'm thinking the engine went way above normal temps because of flawed thermostat/head gasket/pump problem, then, as overflow was whistling away coolant violently blasted at high temp steam. Yes, I would be looking at all things for causes.
/ Kubota Radiator Cap Danger... #20
All water heaters come standard with a pressure relief valve besides being required by code. Wonder why that did not work int he You Tube Phoenix AZ case ?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
light tower (A60352)
2010 Case 580N (A60462)
2010 Case 580N...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
