Making a counterbalance for my mx5200...give me your opinions...please
   / Making a counterbalance for my mx5200...give me your opinions...please #1
MechanicalGuy
Beautiful South
Kubota mx5200
So I have a new mx5200 with filled tires and 100lb wheel weights on each rear wheel. I will be using the weight for a small profile counterbalance for mainly gravel and clay dirt fel counterbalance. My initial idea was to put as much scrap metal in the 55 gallon drum as I could fit, and then pour concrete over it to attain 1500lbs. It would be much less expensive and much less hassle to simply fill it will concrete and just get about 800-1000lbs counterbalance.
Knowing what I have and what I plan on doing, will a simple concrete counterbalance work? Or should I go the extra mile and increase the weight with scrap metal at 20 cents a pound?
Here is the beginning;
   / Making a counterbalance for my mx5200...give me your opinions...please #2
Steel is more than three times as dense as concrete, but you'd need to be more concerned about air space / voids when you pull concrete over; a bit of air will remove any advantage quickly.
Personally, unless you know you can get a lot of scrap into the concrete without air, I wouldn't bother.
Consider also that the farther back the weight is, the more effective the counterbalance is.
   / Making a counterbalance for my mx5200...give me your opinions...please #3
800-1,000 pounds counterbalance will be ample for FEL lifts of 2,200 pounds.
With more counterbalance you will only create deeper tire ruts.
I suggest first filling barrel with sand, then adding water in increments, until you find the optimum weight and no more.
   / Making a counterbalance for my mx5200...give me your opinions...please #4
Cast off brake rotors obtained from most any auto repair shop are a useful source of "heavier than concrete" .
If casting concrete around them vibrate or at least beat on the drum sides to settle the pour.
IT IS TIME TO ENTER YOUR KUBOTA MX5200 INTO YOUR T-B-N PROFILE TO ELIMINATE READER CONFUSION.
Sounds like great advice. Thanks.
You are absolutely right. I'd forgotten about that! Thanks.
   / Making a counterbalance for my mx5200...give me your opinions...please #7
Why make something that can only be used as a counterbalance. I have an 1050# rear blade on the 3-point. Get yourself an implement that you will use and put that on the 3-point. The 1050# rear blade plus 1550# of RimGuard in the rear tires keeps me well grounded.
   / Making a counterbalance for my mx5200...give me your opinions...please #9
Great advise. Yes a good heavy box blade is expensive but I don't know how I would get by without mine or my scrape blade. Excellent attachments.
   / Making a counterbalance for my mx5200...give me your opinions...please #10
I was using my BB as a counterweight but wanted a more compact setup so I did not have to constantly keep an eye behind so as not to whack things with the BB in tight conditions.
I built this unit from scrap steel and leftover concrete for next to nothing. Weighs around 400 lbs
Along with the loaded tires, I can lift a full bucket of wet sand with no tipping and it is much more maneuverableIMG_1385.jpgIMG_1386.jpg
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
2018 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
