Popular mythconceptions
   / Popular mythconceptions #271
Splashback would be nicer with warm water.
A friend spent a crazy amount of money on a toilet that cleans and drys your behind.
   / Popular mythconceptions #273
I tried hot and cold water in my poly ice trays side by side. Same source, same trays, same time in the fridge. The cold froze faster, so my water obviously isn't college-level engineering material. :confused2:
Mom's old single-door refrigerator had the aluminum 'box' for frozen food, whose coils were in the thin walls of that 'ice box', and that had to be defrosted every few weeks. METAL trays, if filled with warm water, could melt through the frost until they contacted the conductive metal of the box & inner coils. Those trays froze faster with their metal to metal heat conduction. Mine DID NOT, so they're just plain dumb.
Now that we've thoroughly debunked those utter fakes "Adam and Jamie(?)" let's one-up them by proving once and for all that the earth is indeed flat. Imagine them saying a .50 BMG bullet won't travel 3' under water, when we know water won't even slow it down. :rolleyes: "Seeing is believing." (inventor of CGI)
I had a mixing valve on a stool a few houses ago. Such a thing IS a 'check valve', and when it stuck open we'd get a spurt of hot from sink or tub before pressure balanced and cold flowed steadily. I found and deleted it when I remodeled. A thick tank cozy minimized condensation after that. Now, many 3.8L-flush closets have ~1" of EPS lining to do that.
   / Popular mythconceptions #274
They had me take mine out myself at home.
There method with me was "take a deep breath and hold it". Tricky bastards yanked it out while I was on the 'deep breath' part. Didn't hurt at all though.
   / Popular mythconceptions #275
I always wondered how far in they went?
   / Popular mythconceptions #277
I quickly figured out that a little distilled water made the process much less painful. :rolleyes:
All the way to your eyeballs, I think.
Sort of, then it circles around inside your skull a couple of times... at least that's what it seemed like. :(
Worth it though, I sleep all night without getting up and can p like a fireman again.
   / Popular mythconceptions #278
Sometimes in warm climates they will install a mixing valve (hot and cold) to a toilet to temper the water to reduce condensation on the tank.
Just built a new house. 2 toilets. They are styrafoam (sp) lined. No sweat.
   / Popular mythconceptions #279
My wife doesnt "snore" ! :)
2022 Kobelco SK85LS Mini Excavator (A54865)
2022 Kobelco...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2014 FREIGHTLINER...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
