Mahindra 2538 coolant flush and capacity
   / Mahindra 2538 coolant flush and capacity #1
duffer
Aiken, SC
'16 Mahindra 2538
Hey all,
Getting ready to do my 1000 hr service, and I'm also going to flush and change out the coolant.
Looked at the owner's manual (better known as fire-starter) and not one word on capacity of cooling system. Any of you that have already flushed out the 2538 system have a notion of how much it takes?
thanx
:mur:
   / Mahindra 2538 coolant flush and capacity #2
No but i have the same machine and would also like to know. Last weekend i was at my farm cutting some small trees and decided to try and push over a pine tree i had planted 18 yrs ago. It was about 10 inches at the base. I pushed it right over and poppod the root wad out . I was amazed at the power. Let me know if you find out any info on coolant amount.
   / Mahindra 2538 coolant flush and capacity #3
About 7 quarts total including the overflow bottle. I used Prestone Command HD antifreeze (yellow band)+ distilled water. Old stuff came out clean.
Thanx R134a !!
Guess my 2 gallon of pre-mix I bought should be just about right.
Appreciate it.
   / Mahindra 2538 coolant flush and capacity #5
Thanx guys, appreciate the insight !
   / Mahindra 2538 coolant flush and capacity #7
How much did you end up using? Putting in a block heater this week or next and getting my materials together...
I used a gallon of concentrate, and diluted it 50/50. Used almost all 8 qts. Have probably a pint of mixture left over for topping off if needed.
   / Mahindra 2538 coolant flush and capacity #9
Thanks!
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
UNUSED 20PCS 1.2 in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 1.2...
PICK UP BED (A49461)
