What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #671
I'll check threads today but they are a standard LS part, used on several tractors.
Here are pictures ..... as promised.
I'll let you guess on thread / pitch.
   / What did you do on or to your LS Tractor today? #674
   / What did you do on or to your LS Tractor today? #675
Awesome! Thank you.
Those gauges are really cool! I have something similar to the ones you see at the hardware store, but are inch only.
I think I got mine at Rockler. Orange metric and black inch. Each ball has both male and female threads and both course and fine threads included.
   / What did you do on or to your LS Tractor today? #676
Thanks Guys.
Ordered a set along with nylon washers.
   / What did you do on or to your LS Tractor today? #677
   / What did you do on or to your LS Tractor today? #678
Found the limits on my pallet forks (XR4155HC). Tried to lift a Genie GR15 mast lift off my flatbed (2345#-which I noted when I checked the serial label after I tried to lift it off).
Loaded it with a regular forklift so I really didn’t think about its weight until I hit the relief valve while trying to lift it off!!
Still pretty good capacity on the pallet forks just not quite enough to lift this mast lift.
   / What did you do on or to your LS Tractor today? #679
Loaded it with a regular forklift so I really didn稚 think about its weight until I hit the relief valve while trying to lift it off!!
Yes part of why i went with bigger tractor was i need to move logs and telephone poles
   / What did you do on or to your LS Tractor today? #680
It's funny I just looked at hp because I probably need a 75hp+ in the future but dont want to have the payment on that yet and 68hp LS had a lot of options standard that other brands dont and I figured I could get by with this for a few years before going bigger after I see how my plans are working out lol my little compact tractor is like 1980s 26hp and i definitely made it do things well beyond the hp requirement of attachments lol
Well BB i sure didnt have a problem understanding what you wrote cant see how a period or paragraph would help but then i would not know where to add them either.
And if i did i would never say anything about it to embarrass you.
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
Zero Turn Mower (A55853)
Zero Turn Mower...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A58018)
2016 FORD F-550...
