50 hour service ALMOST turns disastrous!
   / 50 hour service ALMOST turns disastrous! #22
I dropped the small cap off my gas can nozzle into the fuel tank on my JD lawn mower - somehow. Took the better part of an hour to retrieve. That convinced me to get an all metal, flex nozzle funnel. If I dropped something into the hydraulic oil or engine oil ports on the tractor - could be SOL.
Besides - it's next to impossible to fill engine or hydraulic oil without some type of funnel.
   / 50 hour service ALMOST turns disastrous! #23
I learned the OP's lesson, years ago, when I was a student pilot.
I was on a ladder checking a fuel level in a wing tank of a flight schools high wing aircraft. I Managed to let a fuel level measuring device slip out of my fingers, and drop into the wing tank.
Removing the tank would have meant draining a large amount of fuel, and disassembling part of the wing. Which would have been somewhat expensive. :irked:
After considerable maneuvering, I was eventually able to get a "grabber tool" to hold on to one end of the hollow tube, long enough to get it out.
   / 50 hour service ALMOST turns disastrous! #24
My Deere mower's gas fill opening is about 5" in diameter -- it's ridiculously large. I always wonder why they made it so large. How do they expect people to be fueling their mowers? You could seriously rest the end of a gutter in there and it would fit.
   / 50 hour service ALMOST turns disastrous! #25
My gas tank opening on my JD G100 riding mower is about 3". Easy to drop a small gas can nozzle cap into. Not big enough to get your hand down into. I'm very careful where I place the gas can nozzle cap now.
   / 50 hour service ALMOST turns disastrous! #27
I got this illuminated grabby thingy at TSC. I drop way too many things.
The camera looks good me thinks I need one now.
   / 50 hour service ALMOST turns disastrous! #29
As long as none of this Proctologists will drop a funnel inside a patient :D
   / 50 hour service ALMOST turns disastrous! #30
Years ago I borrowed my neighbors old J.D. skip loader that he had bought from the county at auction.When I finished, I was pouring fuel into it with an old steel fuel can, called a safety can as I remember, with attached flex line, also steel, and the flex line broke off and went into the tank. In the process of fishing it out I found another flex line just like it that had been in there for who knows how long. I know the neighbor had bought the tractor at least 5 years prior and never had a problem.
2010 Chevrolet Express Shuttle Bus (A55852)
2010 Chevrolet...
PALLET OF (6) BOXES OF SAFETY CHAINS (A57192)
PALLET OF (6)...
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
6 HITACHI WEDGEDOCK COUPLER (A57192)
6 HITACHI...
LINCOLN ELECTRIC IDEALERARC DC-600 WELDER (A57192)
LINCOLN ELECTRIC...
