Lawn mowing season at full swing.............
   / Lawn mowing season at full swing.............
Well I got the fuel pump on this afternoon, easy job. I first did the turn motor over test and fuel started pumping out, then hooked the line to the carburetor and the motor started right up. But,,, why is there always a but, the motor has gone back into the surging mode again and cant find the delete button. Guess now it's the carbs turn for attention, ordered a carb kit so when that shows up I'll see how far that gets on the new priority list next weekend, as if I dont have enough stuff to do, in the mean time I'll give it or me a workout tomorrow.
InkedIMG-2946_LI.jpg Sears riding mower - YouTube
While I had the mower deck off and the motor wasn't running anyways, I decided to tweak the idler pulley so's to have the blade belt snug when engage. I advanced the square notch to end of bracket for carriage bolt, didn't measure but looked to be around 3/4" more. Then for the just in case problem, I added 1-1/2" more to the idler bracket and made another square hole, (side note), square holes are hare to make with round drill. As the afternoon was moving faster then I was I forgot to get a picture of added on bracket with square-ish hole, just imagine the same shape-ish bracket just a weee bit wider, then threw some black paint on while warm-ish.
Also another (side note} when changing one thing watch out for the domino effect, there is a little thin> (1/32-ish) belt guide clip that went on the bracket a certain way. Like a L shape, one end goes up by the pulley, the other end goes under pulley where the bolt goes up threw then L's towards the original end on pulley bracket, then a tab bent down to hold from moving. Well the end of bracket got moved. So quick fix is flatten that little tab, tack weld a nail on, cut to 1/2"long, drill 1/4" in bracket, now that pulley clip guide wont move.
Nah, my Stihl brush cutter, kind of a weed wacker on steroids..
Seems to be getting gas, I don't think its getting spark for some reason.. need to tear it apart.
Can we now say ECHO.................................
well good luck with the fuel pump and belt keep us posted
Belt didn't show up today like promised so's to avoid a trip to the money soaking tractor store I dub around with idler pulley bracket, after about a hour got the bracket rebuilt with new holes, now the not so old belt that I have is snug when engage...
   / Lawn mowing season at full swing............. #15
see i knew u could do it - got everything fixed but the surging, i had an old briggs that did that when idling but when WOT it ran fine under load - it was old school and the guy at the mower shop back then told me it was a warn governor shaft/gear etc....and it would have to be taken apart to fix, i opted to listen to it hunt like an old detroit diesel at idle but running mowing it was fine.
   / Lawn mowing season at full swing............. #16
never owned an echo, i have been blessed with good luck out of my stihl stuff
   / Lawn mowing season at full swing............. #17
View attachment 612834 Sears riding mower - YouTube
Check out this video. this guy seems like a goofball but he knows his stuff.. helped me out a lot. He has lots of good videos on small engine stuff!
How Do I Fix a Surging Engine Video (Lawn mowers, tillers, pressure washers etc.) - YouTube
   / Lawn mowing season at full swing............. #18
Echo is fine by me! I have a little top handle Echo that I've had for years... love it.
If I remember right (and I may not) sawyer rob is the one that doesn't like Echo.
   / Lawn mowing season at full swing............. #19
   / Lawn mowing season at full swing............. #20
I've been watching his videos for awhile, and he seems to be the wizard for small engines.
He does have quite a comedic twist.
Yes he is very good at what he does..
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2015 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
