M6060 vs L6060
/ M6060 vs L6060 #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
What are the differences? Why is one better than the other? There is a used M for sale close by and I am deciding whether or not I want to take a look.
/ M6060 vs L6060 #2
Everything is different.
The L6060 is a HST "deluxe" compact. The M6060 is a larger frame size gear driven machine.
SDT
/ M6060 vs L6060 #3
I have an M. All I read on forums from L owners are issues with the different transmissions such as the Glide Shift.
I view the M series as being more basic less frills power train wise which translates into fewer problems long term.
Dave M7040
/ M6060 vs L6060 #4
"Why is one better than the other?" Neither is "better", it just depends on your needs, we have an M8540HDC and L5740HSTC. For us the M8540 is a necessity while the L5740HSTC is in ways a luxury.
/ M6060 vs L6060 #5
The M6040 is an overall bigger, heavier duty machine than my old L4630 yet it is more maneuverable and weight capable.
/ M6060 vs L6060 #7
My Kubota M6040 with Land Pride grapple - Rimgard in the rear tires - Rhino 950 on the 3-point - weighs 10,100 pounds. Yet it's nimble as a pixie. Ha, ha, ha - and my nimble pixie will tear the crap out of my lawn if I start "pixieing" around.
With power steering and directional/independent rear braking - how much more maneuverable do you need.
I've "bulked up" my M6040 to be able to handle Class 2 implements.
/ M6060 vs L6060 #8
"The M6040 is an overall bigger, heavier duty machine than my old L4630 yet it is more maneuverable and weight capable."
More maneuverable???
What the???
SDT
Well, it sounds odd, but he ought to know if he had both tractors. It might be the turning radius or the front end construction. We've got an M59 - a whole different type of tractor, I know - but the point is that tractor is noticibly more maneuverable than any other tractor clost to its size that I've driven. It's as nimble as tractors half its size. The difference seems to be in the front axle, short wheelbase, and how far the front wheels will turn without binding or sliding a tire. Maybe that is what he found too.
rScotty
/ M6060 vs L6060 #9
I think my M7060 is pretty nimble, however, I’ve never owned anything smaller... but I do think it is rather..nimble.. ;).
With the box blade on the back, it’s fine. But with the rear blade on the back, now I’m constantly rubbernecking to make sure I don’t destroy anything in my path. LOL.
/ M6060 vs L6060 #10
Nimble/maneuverable may relate to the operating environment also. Here in the Scabrock it's just stands of ancient Ponderosa pine and bunch grass. I have no problems pulling my ten ton farm wagon anywhere on the property.
If my 80 acres was like is shown in many TBNers photos - completely different story.
/ M6060 vs L6060 #11
What the???
SDT
First of all the wheel spacing on the M is narrower than on the L and with the taller narrower R1's it will turn in a tighter radius than the L.
However, it does tear the heck out of my lawn if I am not gentle when turning.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
Vacuum Tank (A61573)
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2018 ATLAS COPCO XAS 185 PORTABLE AIR COMPRESSOR (A64279)
2018 ATLAS COPCO...
