Timing a NH 565 Baler
/ Timing a NH 565 Baler #1
flyfisher123
Peterborough, NH
Toro Groundsmaster 325d
Can any farmers help?
Broke the pickup drive belt last year on my 565 baler.....discovered the knotter clutch was messed up when I went to replace the belt... FINALY got new clutch...installed it today...can anyone give me step by step instructions on checking and retiming... or better yet upload relevant pages from a manual? (Hay window coming...would love to know baler is 100% before cutting....)
/ Timing a NH 565 Baler #2
Baler timing should be outlined in 565 operators manual. I can't help on timing NH baler as I've always owned a JD small sq baler & I could time those in my sleep.
/ Timing a NH 565 Baler #3
/ Timing a NH 565 Baler #4
I just had a thought post your 565 timing question on Haytalk.com. I'll bet Mike10 or some other member can tell you how to time it.
/ Timing a NH 565 Baler #5
I don’t have pictures but there is 3 dots on each piece make sure they are lined up. And there is 2 lines that the plunger should be centered between
/ Timing a NH 565 Baler #6
Where you pull the gears apart to put the belt on. Is where your dots are.
/ Timing a NH 565 Baler #7
10 degrees before top dead center should be good. measured at full RPM.
/ Timing a NH 565 Baler #8
I never heard degrees utilized in small sq baler timing nor would I know how that could be performed. I've been repairing small sq balers since the late 1960's.
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
1997 International 3800 School Bus (A64194)
1997 International...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
Winchester Sign (A64557)
Winchester Sign...
