Box blade
/ Box blade #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Picked up my new box blade today from my good friends at Michigan Iron & equipment..Pretty stout blade IMHO made by woods equipment company.
/ Box blade #2
IMO thats a bad azz BB ! :thumbsup: Congrats ! From the series # on it I can see its a 7 footer . That top A frame bracket is heavy duty .How much is it suppose to weigh ? Not that you need it but was a hindged back model a consideration ?
/ Box blade
Blade is around 750 lbs.Looked at the hinged model but did not go that route.
/ Box blade #4
Nice looking piece of equipment.
/ Box blade #5
Nice. I have a 66" Woods. They are solid built. I've hit rocks big enough to stop the tractor from moving. Didn't even leave a scratch.
/ Box blade
Had a older 6ft united back blade few years ago and sold it to a friend.Missed not having one so this is the replacement.
/ Box blade #7
Indeed well built :thumbsup: make good counter ballast.
Weld trailer receiver hitch middle of back it will come in handy.
/ Box blade #8
Coobie heres a pic of my old Woods/Frontier BB . Your rite Woods pretty stout . However I like how they did the top link A frame attachment on yours better, the cat 1 and 2 bracket :thumbsup:and match them with Yote orange for the pack crowd . I wonder if thats a Kioti thing or Woods has some in blue etc for like the LS gang ?
/ Box blade
I like it..
/ Box blade #10
I have an HR3584 that works really well, 1100 pounds I think. I knew better, but tried to get by with a much lighter LP BB2584. I couldn't sell it, so I welded some RR tracks to it and use it for counter balance on another tractor. 800 pounds on your tractor should work great.
/ Box blade #11
MIE...Great place to work with.
/ Box blade
Yes they have great sales,service & parts Bar none..I live 70 miles south of MIE,s Kioti dealership and pass 2 other Kioti dealers on the way.That should tell you something.LOL
/ Box blade #13
Great looking box scraper blade.
I have never used one and was wondering if someone could enlightened me on this... I see there is a long 'scraper blade' that runs the width of the box and I assume it's purpose is to scrape off the high points. Then there's a 'sweep' that's attached to the back of the box and once again I assume it's purpose is to level the material... Correct?
Ok. So what is the height of the scraper blade in relation to the sweep?
/ Box blade #14
There's actually a whole lot of ways you can use a box blade. It depends entirely on what work you're trying to accomplish, and what type of dirt you've got. In loose material, I often use the blade on the back like a dozer blade, to push material in reverse. On my Befco box, both blades are the same height. You change the angle of attack of the entire box with your top link. Scraping with the front blade....you shorten the top link to angle the front down. Using the back blade like a dozer....you want the top link set for a level box, (or very slightly angled up in the front). Using the back blade to make a levelling pass....lengthen top link so front of box is high, and rear is low.
If that doesn't make sense, look on youtube, there's a bunch of videos out there showing some of the many ways to set it up.
/ Box blade #15
Good info there NYCheese, thanks!
/ Box blade #16
I've probably put in a couple thousand hours of grading with box blades over the last 25 years, and I still marvel at how they work. I can best describe it as a demonstration of "Chaos Theory" at work. :) Pull one behind the tractor over dirt or gravel and the box quickly fills with material, churns it all about, then distributes it evenly behind, leaving a smooth, level surface. That alone makes it pay for itself the first time you use it. It is truly a marvel of physics and seemingly random motion in action.
As NYCheese says, you can add finesse for particular tasks by adjusting top and side tilt. A top 'n tilt set up with hydraulic cylinders lets you do this on the fly. If you want to tear up the material before leveling and smoothing, lower the scarifying teeth. It's one of the most useful implements you can add, IMO.
Recently "land planes" have become popular as another good tool for maintaining established roads and driveways. It's a more specialized implement. I've heard good things about them, but haven't tried one.
/ Box blade #17
I got an 84" Tuffline, it's about 1,200 lbs and has hydraulic scarifiers, which, I've found, are excellent brakes! :laughing:
The cutting edge (inside/forward facing) is pretty good for curling up sod. I've run my blade and watched it curl sod back over on top of the front of the box blade, resulting in more weight/down force. I've had my NX really grunting!
An hydraulic top link is a MUST. Not sure how anyone can get by without one, as hand adjusting a lot of weight really isn't readily going to happen.
The hydraulics for my scarifiers sucks. There's no check valve: no idea if I can augment or whether I'd have to replace the cylinder. Over a relatively short period of time the entire bar will drift down: it resulted in some broken linkages once, as I backed up and didn't realize that the scarifiers had dropped down. I have a 2x4 holding things up as I don't really use the scarifiers. Might be that this is one of the reasons why this Tuffline was a bit less costly.
/ Box blade #18
The drift is most likely your tractor valve leaking by.
/ Box blade #19
Thanks, Richard. I should probably check that! I am not sure if I've used that valve on anything else: I have three: one is dedicated to top link and one is dedicated for the grapple (full detent). I might swap with my top link to see how it behaves: I have my RC connected now, so testing this way might be easier than swapping the implements (and then having to swap back). It's all fairly new stuff.
/ Box blade #20
And don't despair if they all bleed down. No big deal and very common.
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2018 Volkswagen Passat Sedan (A61574)
2018 Volkswagen...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2016 John Deere 6155R (A64119)
2016 John Deere...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
