Instaling a BHT-1 Moisture Tester
/ Instaling a BHT-1 Moisture Tester #1
xcsp
Berlin Center,Ohio
New Holland TN-55
I am Instaling a BHT-1 Moisture Tester Baler Mounted on my New Holland 565 It says to mount Locate a fl at spot between 12 to 24 from the rear of the chamber, about
halfway up the side, on the UNCUT SIDE of the chamber
NOTE: Readings from the cut side of the bale will result in greater
variations of readings and overall higher readings.
which side is the un-cut side of the baler ??????
Thanks Greg
/ Instaling a BHT-1 Moisture Tester #2
I would say the side opposite from the feed/pickup since that is the side the cutter is on.
Thanks for the help hopefully get to use it next week if the rain will quit
Greg
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
207278 (A52708)
207278 (A52708)
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
UNUSED KJ K4525G-45' X 25' DOUBLE GARAGE (A60432)
UNUSED KJ...
