Round baling with 6 horse (well, mule) power
   / Round baling with 6 horse (well, mule) power #21
I'm going to be contrarian and say that customary measures have evolved over time from being used for actual work. Ten is a lousy unit because you rarely divide anything into tenths. With a standard tape measure divided into 16ths, there's one half-inch mark, two quarter marks, four eighth marks and eight 16th marks. They're all different sizes, and you can just tell by looking which type a mark is, you don't have to count to know the measure. With a metric ruler or tape, you have cm and ten mm marks, the fifth one might be noted somehow but you have to count. A 16th of an inch is the smallest unit usually used it carpentry, it's half a saw blade. A mm is about a third smaller and I find it too small to be useful.
Acres and miles used to be logical but got screwed up. At one time in Europe there were two competing measures for the foot, called the short foot and the long foot. England used the short foot and most of Europe used the long foot, which was 10% longer. At that time a mile was 4800 feet and an acre was 36,000 square feet, which are great units for doing math. England eventually switched to the long foot in order to facilitate trade with the rest of Europe. Rather than redo all of the land records, all of the units of measure above a yard were redefined to be 10% longer. So a mile became 5280 feet and the acre became 43,560 square feet. This was almost a thousand years ago.
Wikipedia;
From all the countries in the world, only three still use the archaic Imperial system of weights and measures:[/B]
Liberia.
Myanmar (a.k.a. the country formerly known as Burma?
United States of America.
If you want "trade" outside the States then you have to adapt to metric. How can you ever compete with China and India if you are the only country in the world that is not metric?(beside 2 third world countries).
   / Round baling with 6 horse (well, mule) power #22
For me in the machining and mechanic world, I would rather use the metric system. One cool bit of trivia...1 gram of water = 1 ml = 1 cubic cm. Zero Celcius = freezing point of H2O and 100C = the boiling point.....it is all based on WATER
   / Round baling with 6 horse (well, mule) power #23
Every body knows to count money in multiples of 10, but when it is distance, acreage, volume and all the other, than they use an incomprehensible ancient system.
Now that is weird, but not for Americans.
Just saying.
Even the Brexiteers? Well, maybe they do now but I'm sure they'll quickly forget.
   / Round baling with 6 horse (well, mule) power #24
Wikipedia;
Liberia.
First of all, Wikipedia is not an authority. I have the ability personally to write anything I want there. Of course, "people" can refute what I say but the principle is that it's open source. So the statement "archaic Imperial system" is just that, a statement made by some person which has not been edited. Considering the length of human existence (even the most conservative estimates place it above 6000 years), the difference in the number of years the two systems have been around is inconsequential.
Secondly, No, you don't have to adapt to metric to work outside of the USA. We have customers in Canada and all orders are in Inches. Pretty sure we are not the only ones...
Do I think the Metric System is "Better"? Maybe. I DO think it's generally easier, and I DO wish the USA would convert, but I don't see us "struggling" as a 4th rate 1st world country in the global economy because of it.
BTW, why in the world would we want to compete with China and India? I sure don't, and won't.
   / Round baling with 6 horse (well, mule) power #25
The Fahrenheit scale is based upon the weather, with zero being about as cold as it gets most places people live, and 100 being about as hot as it gets. Daniel Gabriel Fahrenheit came up with the scale after observing temperatures in his home town of Danzig, Poland. He wanted to have a scale that could be re-created anywhere by anyone, so he set his two reference points as the freezing point of water and human body temperature. He set them at 32 and 96 so they would be 64 degrees apart to make it easier to physically make his device. The interval could be divided into 64 equal parts by dividing it in half six times. It's actually pretty clever.
The scale was later revised to make the boiling point of water 212, which gives 180 degrees between freezing and boiling. That revision pushed human body temperature up.
2022 Kubota RTV-XG850 4x4 Utility Cart (A56857)
2022 Kubota...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
TANK MANIFOLD (A58214)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
