air in lines?
/ air in lines? #1
NYCheese
Near Binghamton NY
Kioti CK3510se hst TLB
Recently picked up an old homemade 3pt wood splitter for cheap. Only thing it needed was new pioneer connectors on the hoses, as the old ones were leaking. In the process of changing these, I lost probably about a quart of fluid. There's no bleeder on the cylinder on the splitter.... do I just hook it up to the rear remotes and cycle it to get the air out? It's a vertical mounted wood splitter, so the cylinder is vertical, if that matters.
/ air in lines?
Just cycle it till you can get full pressure to split...
fDale
There's no risk to the pump on the tractor to do this? And what about air getting trapped in the cylinder on the splitter, since it's mounted vertically?
Just wanna be 100% sure before I do it, because I really don't have any experience working on hydraulics at all.
/ air in lines? #4
Connect and cycle as described above. You are overthinking this one.
/ air in lines?
I can't disagree with that at all....but I have a good reason. I just started flying a paramotor this summer, and on my very first flight, my motor died in the air. I've been overthinking EVERY decision the past few weeks lol.
/ air in lines? #6
The air will work itself out. Note the reservoir, which is the pump intake, isn’t pressurized. So any air in the system will get cycled out through the reservoir.
.......no wings or flight involved!
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
New/Unused Fuel Heater (A61166)
New/Unused Fuel...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
