Best MFWD tire brand?
   / Best MFWD tire brand? #11
An old saying applies here.
"Good quality, cheap, pick one." :)
   / Best MFWD tire brand? #12
They are probably radial firestones not like a bias tire, I would also recommend a radial tire, are they better in the mud? probably not. I plan on putting them on my tractor one day.
   / Best MFWD tire brand? #13
Call your local NH dealer. They usually have OEM take-offs for less than new price.
   / Best MFWD tire brand? #14
What goes on new tractors is a brand they can get in quantity at a low price. You will not find premium tires on economy level tractors. You will find higher dollar rubber on higher spec tractors.
   / Best MFWD tire brand? #15
You know, you mention that, and it suddenly occurs to me that as one who tends to mill around tractor dealer lots from time to time, I find it pretty amazing how many brand new tractors on dealer lots have flat tires..
   / Best MFWD tire brand? #16
Seems to be a lot of Titan tires on new units. I don't know the best ones but I do prefer radials on the rears. Don't know how good the tires from Gensco are. I purchased a set of aircraft retreads for my FORD 4610 fronts. 18 ply and never had a puncture, They are importing tires from Malaysia and have higher ply counts for them. Might be worth a look.
Gensco Tire. Home of the no flat aircraft tire.
   / Best MFWD tire brand? #17
My 2009 Kubota M6040 came with Titans on the front and Firestone on the rear. Works for me. The extra $$$ for radials - I would be very hard pressed to justify the added cost. I see nothing, that I do, to need a potentially slight increase in traction. It simply is what it is.
   / Best MFWD tire brand? #18
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A56858)
2008 Ford E-350...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
Electric Utility Cart (A56857)
Electric Utility...
