Jinma 354 le ty395e
/ Jinma 354 le ty395e #1
ericsloan
hamptonville, nc
jinma 354 le
Just replaced head gasket and started ran on 1 and 3 cylenders bled fuel lines all getting fuel all three new injectors had some light white smoke or mist comming from oil fill cap. New oil and filter very slow to rev up.
/ Jinma 354 le ty395e #2
Important to know; why did you replace the head gasket?
Make sure the valves are adjusted correctly. if it is un-burned diesel coming from the oil cap, than don't run the engine. The cylinder with un-burned diesel is not well lubricated.
Best to start with a compression test.
Replaced head gasket antifreeze in cylinder 2 and 3 oil sump was full of aintizreeze and oil mixed
/ Jinma 354 le ty395e #4
There's really only two reasons a cylinder won't fire: either there's no fuel, or no compression.
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2012 HEIL TRAILER (A65643)
2012 HEIL TRAILER...
(5) John Deere Front Tractor Weights (A65640)
(5) John Deere...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
