Sa424 pto
/ Sa424 pto #1
Rutman
Bostic, NC
Yanmar sa424
Haven’t used the pto yet but when I turn it on,
It makes a clattering noise while it is turning.
Is this normal or is it supposed to run quiet?
/ Sa424 pto #2
Usually pto's are relatively quiet. You will hear something like gear whine, but it should be barely heard. If there is "clatter" it should be checked. Are you turning it on at idle or a higher rpm? Higher rpm and with a load may make it go away.
/ Sa424 pto
Yes, I was turning it on at idle. Assumed that’s what you should do.
I’ll crank up the rpms and try it and see what happens
/ Sa424 pto #4
Yes, you do turn them on at idle, or just enough rpm's to keep the tractor from stalling when an implement is attached. I would still engage the pto at idle, then increase the rpm slowly to see if the noise decreases or goes away.
/ Sa424 pto
Thanks,
Will check this after work today.
iDrive TDS-2010H...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2012 PROCCO 130BBL (A65643)
2012 PROCCO 130BBL...
