Loader Can't find Montana loader specs anywhere.
   / Can't find Montana loader specs anywhere. #1
Rowdy Redneck
Grundy
Kioti DK40SE HST
Hey everybody, as the title suggests I am looking for loader specs, specifically for the R4944 and 3940. Tractordata has nothing and I have been unable to turn up anything on Google. Any help would be greatly appreciated.
   / Can't find Montana loader specs anywhere. #2
I copied the specs when I bought my 3940..
Hey MWB, thanks for the reply! That is actually really stout.
   / Can't find Montana loader specs anywhere. #4
Any idea how to adjust pressure? My 4344 seems weak compared to those specs.
   / Can't find Montana loader specs anywhere. #5
I think there are two adjustments; one is specifically for the loader and should be located on the joystick control. The other is for the 3 point lift and rear remotes; that one should be on the control block for the rear remotes, or possibly under the foot tray where your loader control is connected.
Before adjusting I would put a pressure gauge on a loader line and check it (buy a gauge and a matching pioneer fitting, easy to check anytime). I am not sure what the pressure spec should be but I believe around 2000 - 2200 psi.
   / Can't find Montana loader specs anywhere. #6
Found a separate block that runs into loader valve. This has a nut with Allen head bolt in the middle.
   / Can't find Montana loader specs anywhere. #7
   / Can't find Montana loader specs anywhere. #8
I see the Montana 100 loader specs only are for tractor models up to 4540. Does anyone have specs for the 5740c. I have a bent rod on one of the bucket cylinders and am having a hard time finding a replacement. Any help would be greatly appreciated.
   / Can't find Montana loader specs anywhere. #9
I assume you have the curved loader arms, which would be the Model 115 loader made by Ameriquip. I've attached a Spec brochure.
Dealers are as follows:
Diamond R MO 573-455-2617
Trailswest AZ 520-586-0500
A hydraulic shop can make a new rod if need be. If you have the straight arms it's made by Ansung in Korea. I have a manual for it, but no parts support available here.
View attachment Montana 115 Loader Specs.pdfHope that helps.
   / Can't find Montana loader specs anywhere. #10
View attachment 610029Hope that helps.
I have the straight arm Ansung one. That's the problem I'm having, no one can give me specs on it. I priced out getting a rod made and they want $650 just to make a rod then I have to buy new seal kit and get cylinder cleaned and checked. I was wanting to buy a new cylinder because I'll have close to $850 in this one. From what I've found on new cylinders, they start about $200 - $600.
16001 (A55853)
16001 (A55853)
Mower deck storage axles
Mower deck storage...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
LIGHT TOWER (A56857)
