Wrong shop manual
/ Wrong shop manual #1
chevy
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
This morning I picked up the special order shop & parts manual for my CK3510SE tractor.
After lunch I was looking through the manuals & discovered that the shop manual is for the regular CK3510/CK4010 tractors. Not the SE models. The parts manual is for the SE models.
Does anyone have the part number on the shop manual for the CK3510SE/CK4010SE tractors?
Anyone need a shop manual for a CK2610/k3510/CK4010?
/ Wrong shop manual #2
My machine is an old pre SE / 10 but I thought that CK35SE and CK3510 were the only options. Is there really such a thing as a CK3510SE?
/ Wrong shop manual
There are differences other than just added options. The SE models have tilt steering wheel, a single brake pedal that is mounted from above. Clutch pedal is mounted from above. Parking brake lever is on the steering column. Electric PTO, switch mounted on right fender.
I do not know if there are any differences in the power train. Those may seem like minor differences, but they are things that would need to be explained for a service tech in a shop manual for repair & adjustment.
Kioti website CK1SE Series | Kioti Tractors
/ Wrong shop manual #4
I just picked up my CK3510SE manual last night. Did you get one yet? I have electronic prints in PDF format, but the rest of the manual is WAY to big to copy. Let me know if you need the electrical stuff.
/ Wrong shop manual
The information the dealer had did not show a service manual for the CK3510SE. So I still have the regular CK3510 service manual. Do you have a part number for the service manual you got?
/ Wrong shop manual #6
Manual part# is KI-DHH5-W01. Cost was $150 but well worth it. Lots of great information.
/ Wrong shop manual #8
Sorry to resurrect an older thread, but where were you able to get this shop manual from? I haven't had any luck finding it using that part number. Thanks for the help.
chevy - did you have any luck?
/ Wrong shop manual #9
Any Kioti dealer should be able to order it for you. (DHH5-W01 is in stock at Kioti.) Most dealers probably do not keep extra manuals in stock - which is likely why you can't purchase them online.
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
F-150 4WD (A63689)
F-150 4WD (A63689)
