Pumping a lot of water from basement sump what to do with it? Irrigation?
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #71
I am not wasting time to read the whole thread but I question your calculation. 25k gallons a day does not sound plausible.
If you'd read the whole thread, you'd see his calculations are correct. ;)
It's a shocking amount of water, but seems to be the case.
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #72
I have a question for the OP. How much property do you have? Maybe a simple sketch would help, top view showing road, driveway, house, property line (with acreage). Doesn't have to be accurate, rough simple sketch.
Thanks.
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #73
I would drop the water on a water wheel,, connected to a generator,,
Then I would use the electricity produced by the water wheel/generator, to pump the basement water,,
That would leave me with a net cost of $0,, therefore I would not care how much water needed pumped,,, :cool2:
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #74
That's a perpetual motion machine & they dont work under ideal circumstances. Much less with pumping losses, friction & the basic fact you need to raise the water above it's starting point.
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #75
Hmmmmmmm,,,,,, there is always a "FIRST",,,
:laughing:
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #76
Reason I asked how much land is if the OP has acreage, it looks like you could put in a lake. If basement is, say, 10ft. below ground level, lake could be 30ft. deep. Water could be gravity fed by a pipe (correct size for rate and distance). image_2019-06-17_15-14.jpg
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #78
Reason I asked how much land is if the OP has acreage, it looks like you could put in a lake. If basement is, say, 10ft. below ground level, lake could be 30ft. deep. Water could be gravity fed by a pipe (correct size for rate and distance).View attachment 609496
You forgot that he has this part to deal with....
   / Pumping a lot of water from basement sump what to do with it? Irrigation? #79
This lot is exactly 1 acre. I did capture some images from satellite last night. I’ll get them on when I get a minute. For all you “implausible” posters. Fine. Just know I’ve been a systems engineer including hydraulics for 25 years. Flow. Pressure. Pump sizing. Line sizing. That sort of thing. Numbers are my thing. BUT let’s say I’m off by 1/2 just for fun. Now. I have 10k gal a day. What do I do with it?
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox HD-78STD...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2014 Dodge Charger Sedan (A55758)
2014 Dodge Charger...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
