3-Point Hitch Engine stalls when engaging Bush Hog mower
/ Engine stalls when engaging Bush Hog mower #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Haven't used my 770 PTO mower much, and it has sat for a year or two. Used the tractor a couple years ago to till with no problem. Stored inside.
Hooked up the mower today, fired up the tractor & all it wants to do is stall the engine when I slowly engage the PTO. Run it up to over 2,000 rpm and it still stalls.
It has had a hydraulic problem for a long time, the 3 pt. hitch will slowly drop down and it has done that for 10 or 15 years. Had the Massey dealer look at it (he was closest) and he couldn't find a problem and they talked to a retired JD mechanic & he was no help.
Any suggestions?
Thanks.
/ Engine stalls when engaging Bush Hog mower #2
Could it be something binding up underneath your bush hog like wire ? Do you have a shear bolt on hog or a clutch ? Could your gearbox be frozen on your hog? Have you treid engageing pto without any pto shaft to it to see if it stalls ?
/ Engine stalls when engaging Bush Hog mower #3
I always start my PTO at lower engine RPMs like 1200-1500. Then throttle up to full PTO speed.
/ Engine stalls when engaging Bush Hog mower #4
Step 1.
You need to test the tractor and the bush hog separately to see which is problem.
If you unhook pto to bush hog, can tractor turn pto on?
With mower raised, can you turn the mower blade?
/ Engine stalls when engaging Bush Hog mower #5
Step 1.
What ^he^ said and with pto disengaged, does tractor take off from standstill without bogging?
/ Engine stalls when engaging Bush Hog mower #6
.... but if i had to guess, might be growth in fuel tank from sitting around for 2 years clogging filter and it’s fuel starved.
2021 CAT 289D3 (A61166)
2021 CAT 289D3...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
2015 FREIGHTLINER CASCADIA 125 6X2 T/A SLEEPER TRUCK TRACTOR (A59909)
2015 FREIGHTLINER...
TANK MANIFOLD (A58216)
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
2006 Hypac C530AH Pneumatic Wheel Compactor (A61567)
2006 Hypac C530AH...
