lawn mower blades stop spinning
/ lawn mower blades stop spinning
It appears that the blades are firmly attached and there is no obvious damage to any of the pulleys or belts. There is a small crack in the metal piece that goes around the blade. I think it's called the "spindle assembly". Could this little crack be causing my problem?
Actually I think it's called the mandrel housing. It'll take them 2 weeks to ship it to me.
/ lawn mower blades stop spinning #22
Yes, the spindle housings being broken keep the belt from being tensioned properly. One would think they would be common - even in Ontario!
Thanks. It's not quite as easy in the States, but I'll try calling around to the small machine shops and see if anyone has one.
/ lawn mower blades stop spinning #24
Find sale(s) of aftermarket parts.... Most mower seem to be made by MTD and all use pretty much same parts.... I can get aftermarket (generic) parts about 1/2 the cost of JD parts and side by side the look identical.... Internet can be big help, and yes there are sale organisations that can export from US to Canada....
Some place on chassis will be a nomenclature tag.... There will be a number like XXX.12345678... The XXX code is who manufactured the mower (by contract) for craftsman/Sears...
Craftsman OEM List | VintageMachinery.org
Ppossibly your part...
Yt3 Craftsman Lawn Mower Parts: Fast Shipping
Spindle Assembly 53219287 | RepairClinic.com
Amazon.com: 53219287
Dale
/ lawn mower blades stop spinning #25
Typically the whole assembly is a better way to go, though not always necessary . Many ship with the bolts, but if not there is a 2 out of 3 chance that you will need them.
Dale
Thanks a lot for looking this up. It looks like the correct piece, and I ordered one just like it earlier today. The problem is that I can't get the exact part number because I don't have the parts catalogue. I contacted Sears to try to get the catalogue, or any information on the tractor and they said that they don't have anything about it in their system anymore because it's too old. It's only 15 years old, which suggests that Sears doesn't expect their products to last very long and I can't say I'm enthusiastic about every buying a Craftsman product again for that reason.
But this part you suggested (532192870) looks like the right piece and hope it is.
/ lawn mower blades stop spinning #29
Go with the Occam's razor theory.
The shaft key was likely sheared so the pulley is spinning freely on the shaft. Get a puller to remove the pulley, clean up the key slot and pulley slot, then put in a new key. Try this first and spend around a dollar for a new shaft/pulley key, measure so you get the correct size. Some local parts stores will rent you a puller if you don't have one.
/ lawn mower blades stop spinning #30
It’s probably not a problem with either blade. Otherwise the not damaged blade would continue spinning.
/ lawn mower blades stop spinning #31
A word of caution here is that the OP did not post the chassis number from below the seat as far as I see. Though likely a Husqvarna built tractor, it could be an MTD built unit. Parts are different. In either case checking the pulley spline and trueness is a good idea, no key on a deck pulley and no need to worry about a puller.
I replaced the spindle housing and the mower is working well again. I appreciate everyone's input on this forum. Thank you!
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
MAN BASKET (A64553)
MAN BASKET (A64553)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
