How much horsepower for different mowing situations
   / How much horsepower for different mowing situations
Well I want to do it as quick as possible. I'm cheap so I want to spend as little as possible. I'm either looking at newer 4x4 machines or older 1970s tractors, depends on what type of HP I need.
   / How much horsepower for different mowing situations #12
At our place:
5' w/ 16ish HP takes around 1:15 for 2.25 acres
5' w/ 21 HP still takes same time.
6' w/ 32 HP takes about 1:15 for 3.5 acres
91" w/ 42 HP, somewhat less. Deck was around $600 and took a fair amount of restoration work. I haven't been paying much attention to the time. Not being in a rush also means a nicer ride and less abuse to the equipment.
   / How much horsepower for different mowing situations #13
I ran a 7' rfm behind my previous L3410 (27 PTO HP) without issue on a maintained fescue field for many years. Some mowers are heavier than others, so if you're pushing the size envelope you may need additional weight up front.
   / How much horsepower for different mowing situations #14
Its going to be difficult to match high speed and cheap mower UNLESS you purchase a used JD390 and a used
JD gear drive mule like a 3020 which would fit well.
if you find a tricycle 3020 you can still obtain a conversion kit to make it a wide axle row crop tractor with floatation tires.
A used 3020 would be a great find even as a winter repair rebuild/fuss over as they were real work horses and the shuttle
shift is a godsend for slow mowing in heavy brush.
If you want a mule lower to the ground you could swap the 3020 tires and wheels for the nearest size front and rear combine tires and wheels.
There's limited supply of flail mowers used but I'll keep looking. Titan makes a 6 foot wide model that is affordable and has some good reviews. I'll have to keep searching.
At our place:
Thanks for noting your personal experiences!
   / How much horsepower for different mowing situations #17
I maintain about that much land. Around the house, I use a zero turn. Before that, I had a riding mower. Both did a nice job of making the lawn look great. An acre or two of really nice a lawn around the house is plenty. I also have a 7 foot finish mower that does a nice job when mowing straight lines or gentle curves, but it's really not all that great for getting in and around the trees, or close to the house and fences. It also doesn't leave anywhere near as nice of a finish as my zero turn does. I've had it parked and off to the side for several years now and will probably sell it one of these days. To maintain my pastures, trails and around my pond, I pull a 6 foot rotary cutter, also called a bush hog by many with a 37 hp open station 4x4 tractor. It's gets the job done, but it's probably borderline on having enough power. I will mow stuff that's over my hood with it, but I have to be in my lowest gear to do this. On foot high material, I can cruise along in mid range 2nd gear, which is my fastest speed for mowing. I will still downshift when I hit some really thick stuff, or have to go up a steep hill. If I was to do it over again, I would get 45 hp, but when I do buy my next tractor, I'm going for something in the 80hp range or more with a cab and I will pull a 15 foot batwing. There are just too many other things that I can be doing if I spent less time mowing pastures.
Based on what you have asked, I would pass on the finish mower and get a riding mower. Changing from rotary cutter to finish mower isn't something you want to do all the time. Once my rotary cutter is hooked up to my tractor, I rarely take it off and when I do, I REALLY think about it first and try to come up with any other option to not have to take it off. The older your stuff becomes, the more effort it takes to hook it up.
Get a 40hp or bigger tractor and a good quality 6 foot rotary cutter.
   / How much horsepower for different mowing situations #18
I just sold my Ford 1900 30hp PTO with a RD7200 Finish deck. I cut 4 acres with it and when the grass got high after 3 weeks it was everything it could do to cut it. It would heat up if I pushed it too hard and scalp way too easily. But like mentioned if you have a Brush hog deck with always sharpened blades you can probably get a good enough cut from it on a finish lawn job. But, I would consider too to use a ZERO turn or a lawn tractor with a nicer cutting deck around the house. You'll be happier with the cut and it's too hard to maneuver the big tractor around sensitive house materials (mulch, wishing wells and the like) Ask me how i know ? HA! yeah, like Whoops honey! Didn't mean to run over those Rose bushes!
Steve
   / How much horsepower for different mowing situations #19
Between my 5 acre yard and my daughters 6 acres across the road i am mowing every day. Iuse a 60 inch cut zt for about 5 acres of it . the rest i use my mahindra 2810 with either a 5 ft rotary cutter or a 6 ft finish mower. The finish mower will pull hard on the 23 pto hp if i let the grass get much over 6 inches . I would look at 35 to 40 hp tractors at a minimum.
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2021 BOBCAT T870 SKID STEER (A52709)
2021 BOBCAT T870...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
