Best implements to grind sod clumps, remove rocks, and flatten a pasture
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #11
As per Leonz, a small rock picker followed by diamond harrows.
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #12
That's the perfect job for a pto driven power rake. I scored a pto driven 6' off CL for about 1/2 price. I run it on a 55hp tractor. Would't take full price for it now. I'd stick with the 5' rake with 30 hp.
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #13
For 3 point hitch equipment, how does a power rake differ from a rototiller? Can a rototiller be used in place of a power rake?
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #14
I'm never in a big hurry. I drag a chunk of chain link fence behind my ATP. It's not the fastest way but it's dirt cheap and will eventually do a great job.
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #15
I have both, and the answer is yes and no. The rake leaves a finer finish, and also can angle so it pushes the rocks and debris to the side. A tiller just mulches it all up and lays it back down and is usually meant for deaper work.
I used my tiller and the York rake many times before I bought the Harley Rake. It can be done, but the HR makes it quicker. Even after the HR, I still go over it with the York rake just to smooth it out. After I plant the seed, I run the York rake backwards, and it covers up the seed pretty well.
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #16
Thanks for the advice everyone. I was afraid that a power rake would be the best solution. I'll look at the various harrows.
Not much available in the way of rentals around here, but it might be worth a drive if we can find one.
There is a nice Woods power rake in the PA area on Facebook Marketplace right now. Asking just over $4k. I was going to go look at it, but didn't want to make the 8hr round trip.
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #17
What Jeff and Oosik said. you don't need a pricey power tool that will choke or break on 'dinnerplate'-sized rocks. I carve sod from the edge of the driveway, curbs 'built' by POs plowing snow with a blade best left to o'pavement use. Sod lumps result. I too use a chain fence drag, going over the clumps pulled by the golf cart.
Oosik found what I did to do such a 'smoothing' job, and sweeping u-turns leave no trace on adjacent mowed areas, actually blending the edges. 'Sod clumps' become fluffy 'hair-balls' as after a few passes the dirt crumbles from them.
For big scale jobs, I salute Jeff9366's suggestion of a chain harrow. I also agree that a disc harrow is good for this kind of work. Where I have more roots than rocks, I start with a chisel plow or subsoiler, then I disc, then remove rocks. I always like to vet what tools I have vs look for a place to store another PTO implement that should be kept outdoors the 90% of time it sits. :2cents:
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #18
A rock rake will windrow rocks and seperate material.
A rototiller won't help you get from this:
To This:
The Harley Rake certainly will
   / Best implements to grind sod clumps, remove rocks, and flatten a pasture #19
Did this yesterday with a harley take. 20190609_180245.jpeg20190609_180551.jpeg
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A52706)
UNUSED RAYTREE...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
