Best Pole Saw?
/ Best Pole Saw? #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I'm needing a pole saw to trim low hanging limbs. I have about 6 acres of overgrown pine trees, and hundreds of Mountain Laurel that surrounds every tree, that needs to be cleaned up.
Haven't set a price range yet, but I suspect "good" ones are pretty expensive. On the other hand, I want one that will last. Any suggestions on which brand/model?
/ Best Pole Saw? #2
stihl
gas or battery
telescoping or not depending on how high you want to cut
telescoping are heavier and unwieldy but they get places the other cant
/ Best Pole Saw? #3
Agreed. We started to get a few of the battery type telescoping pole saws at work recently. I've been very impressed with them. Extremely light and well balanced. I would still recommend gas for heavy use.
stihl
gas or battery
/ Best Pole Saw? #4
There are GREAT reviews on the battery powered Lynxx pole saw from Harbor Freight..
I have a Remington gas powered pole saw that I have all the attachments for.. its nice to be able to switch to whatever I need to do..
BUT its a bit heavy..
I have had to replace the carb, on account of laziness.. I left gas in it..
The Lynxx has been reviewed after running all day w/ the battery still charged.. They even bought a 2nd battery but have yet to use it..
/ Best Pole Saw? #5
Thread title
"Best Pole Saw"
Many are pretty good. Just my opinion.
/ Best Pole Saw? #6
I was considering the lynx because they were inexpensive. I used to have a troy built the I broke twice but I was able to take the middle section out and use it as a 5' unit. I used it a fair amount like that because I could just reach into bushes easily and cut low branches etc. Do you know if the lynx can come apart and be used as a short unit? My stihl is unable to make that short. If they made a real short stihl I would buy it.
/ Best Pole Saw? #7
I have the Stihl HT101 12' telescoping saw. Had it 5 years..works great. I run 100% gas in all my engines...which makes a big difference ! Paid $500....but well worth it.
/ Best Pole Saw? #8
sounds like a good choice
/ Best Pole Saw? #9
100% gas and it hasn't seized up? I use 50:1 oil mix in my 4 year old Stihl Kombi. :D
/ Best Pole Saw? #10
I first bought a Troybuilt that worked ok till I ran over the powerhead with my RTV (knew I should not have laid it on the ground behind me). The rest was ok. I priced some of the Stihl and echo power heads but they were just too expensive. I got the Poulan with the saw attachment for much less (about half the price) than just buying a big name engine.I have had to replace the chain twice due to hitting steel objects like fence post while trimming the overgrown fence line but no damage to the saw. The engine is a bit heavy but it came with a tiller attachment that I have actually used a few times in the garden and flower beds.
For items that only require occasional use (like once a year), I cant see paying $500 for them when a $150 one will work just as good. If you are trimming professionally or need one daily then perhaps the lighter weight would be worth the triple price. As for me, if I get tired of holding up the saw, I just take a break. I try to completely remove all the gas from the tank and run the carb dry when storing. So far that has worked well for me.
/ Best Pole Saw? #11
Sounds like the OP has serious trimming to do.
I loved my troybuilt til I cut into a sapling bent like a U with a snow load. It shattered the whole housing when it flung the tree. I used it without the middle piece most of the time cause it was easy to handle
/ Best Pole Saw? #12
I use a 16' piece of aluminum T-bar and a Craftsman reciprocal saw. Tie wrap the saw to the pole, tie wrap the trigger closed, pop the battery in, and go to work. Just like any other pole saw you have to be careful not to let it drop when the cut completes. When you bring it back down just hand over hand to the saw and remove the battery.
/ Best Pole Saw? #13
Had bad luck with a "Poulan" pruning saw;Stihl if you can afford it.Milwaukee makes a really nice "battery powered" saw;nice about that is that it can be a combo tool.Purchase two batteries and you will wear out first.A buddy of mine just purchased the chine saw and pruner.
/ Best Pole Saw? #14
I bought a Stihl HT103 ( 12" bar), 16 lbs a couple years ago. I need all the help I can get in my old age. Being just a home owner it should last me on out. As to tiring, I just take a brake now and then, but keep working until my chore is done.
BTW, I've found that the powered pole saw is great for limbing downed trees. One can drop the limbs without getting up or into the tree.014.JPG001.JPG
Cheers,
Mike
/ Best Pole Saw? #15
I like that
/ Best Pole Saw? #16
Explain the 100% gas. Am I missing something? I thought it was common knowledge and practice to use 2 cycle oil mixed with gas in all 2 cycle engines.
/ Best Pole Saw? #17
i assume he means the premixed 12 dollar a quart gas from the stihl store. there are times i have considered it
/ Best Pole Saw? #18
This is my limb trimmer - always starts but runs out of gas quickly!
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
1973 FRUEHAUF 26' ALUMINUM DUMP TRAILER (A64276)
1973 FRUEHAUF 26'...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
