Mowing Radiator filter on JD2038R
/ Radiator filter on JD2038R #21
Beenthere,
You are correct, two of the radiators are oil coolers. For reference, I live in Southern Illinois. I don't think this is a European issue.
There are three radiators... engine coolant, oil cooler and fuel cooler.
/ Radiator filter on JD2038R #22
The current 2038r is a brand new tractor. It was re-designed from the ground up and is very different from previous versions. That could also explain why the parts catalog is not yet complete. It's technically a larger frame tractor than it used to be, based on the 3e chassis but with 2r series features. I bet as some time goes by the p/c will get updated, but wouldn't imagine that it would be terribly difficult to design something.
I've done quite a bit of parts research on the new 2032R/2038R. The on-line parts illustrations are complete.
jgayman,
Thanks for correcting me re: the radiators & their exact purpose. I did not realize one was a fuel cooler but I will take your word for that.
SI2305
/ Radiator filter on JD2038R #24
It is clearly marked as such in the parts illustrations. The fuel cooler is something new on the 2-series as previous models did not have it.
Why does the fuel need to be cooled? Does it get warmed somehow?
/ Radiator filter on JD2038R #26
As you know, on these small common rail diesels the fuel is constantly being circulated from the tank through the system and back to the tank. As a result the fuel heats up. Apparently keeping the fuel cool enhances fuel injector pump life and the cool fuel also provides higher performance. Do a google search on diesel fuel coolers and you will find tons of info.
/ Radiator filter on JD2038R #27
My 2014 2032R has screen, collects a lot of debris during use
/ Radiator filter on JD2038R #29
JD eliminated the radiator screens on the Gen-2 2-series.
I just bought a 2032r wish they still had the screen. on my old tractors i made a screen thats easy to clear to prevent radiator from clogging up.
/ Radiator filter on JD2038R #30
Wonder if my 2019 2032R which is supposed to be the same as the 2038r except for the turbo has three also? Two weeks yet till delivery
/ Radiator filter on JD2038R #31
Yes, 2032R and 2038R have the same three radiators.
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
Informational Lot - Financing (A63688)
Informational Lot...
JOHN DEERE 4000 DIESEL TRACTOR (A63745)
JOHN DEERE 4000...
2020 MACK P164T DAYCAB (A63569)
2020 MACK P164T...
LEINBACH POST HOLE DIGGER (A63290)
LEINBACH POST HOLE...
