JD 5205 Sputtering issue
/ JD 5205 Sputtering issue #1
Firefighter912
GA
JD 5205 MWFD
My tractor has been doing this every now and again, but it has started to do it worse now.
The issue is that when I am going the tractor wants to sputter. Over time I notice more blue smoke coming out of the exhaust until i stop or until the sputtering stops.
I have no idea what is causing this issue. I changed the fuel filter and it ran fine for a bit but started again.
My buddy borrowed my tractor last week and he got some water out of the fuel seperator/filter. He said when he opened the drain valve that he could hear suction through the filter but the tractor was turned off. Could it be the fuel cap?
I notice there is a small inline silver filter behind the engine. Maybe that is the issue? What can it be?
Here is a video of it. You can hear how it runs. I am using the foot gas pedal by the way so I make the rpms drop.
JD 5205 Fuel issue? - YouTube
The fuel cap is easy to check - just leave it loose and run the tractor but don't you have two fuel caps on your 5205?
Yes sir. Two of them. I am going to get that inline filter and loosen the caps.
/ JD 5205 Sputtering issue #5
It is unlikely, but I suppose possible, that both of your fuel caps became clogged at the same time. Let us know how it runs after you have changed that filter.
Replaced the inline silver filter.....now it runs...great! Thanks everyone!
/ JD 5205 Sputtering issue #7
I think you had better investigate the reason that filter was clogged enough to cause problems.
WOLVERINE TRENCHER ATTACHMENT (A64277)
WOLVERINE TRENCHER...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
New/Unused 110V Diesel Pump with 50ft Hose (A65583)
New/Unused 110V...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
