Doubt I can get this old Cletrac running...
   / Doubt I can get this old Cletrac running... #111
A lot of work going into that ol'girl.
She's coming along and looking good.
Tracked vehicles are nice till you have to start working on them, then it seems like it never ends.
   / Doubt I can get this old Cletrac running... #112
Just a quick tip about that hammer pictured. Take a piece of pipe that's comfortable to grip and weld to onto the rebar handle. I used to have a similar hammer and it was always twisting out of my grip and helping me flatten my fingers. I welded a larger piece of pipe on and it's a whole different hammer. A lot easier to use and you can hit hard and accurately with it now.
I like the way you are documenting this project with pictures. It lets us all enjoy it. Thanks
Edited to add: I don't know how much you are going to use the crawler but I noticed that the sprockets have a bit of wear on them. You could put the wear on the other side of the teeth by switching the sprockets side for side. It's a lot of work I know but you are already half ways there. Just an idea.
Great idea!
Absolutely .....swap the sprockets!
A cheap (I did not say easy) way to head off an major issue that will certainly arise if you do nothing.
   / Doubt I can get this old Cletrac running... #113
An excellent idea, AND after seeing the condition of the left side, opening up the right side to replace the sprocket bearing should be done. Easy for me to say....
Resorting to the "universal wrench", aka acetylene torch, was inevitable. I once had to cook an FEL subframe for 1/2h with a torch to get the loader off (photo)!
Anyway, I love the pix, MD. Keep 'em coming.
   / Doubt I can get this old Cletrac running... #114
Any chance of damaging stuff when a lot of heat is used?
The old Ford factory service manual for Model A cars cautions against using heat...
   / Doubt I can get this old Cletrac running... #115
It's a good thing the screen inside the bull gear/spur gear housing is intact. Otherwise those bearings would have gotten into the transmission. Interesting project. B.
   / Doubt I can get this old Cletrac running... #116
if used on tempered steel, it will soften, and remove the temper, making the steel too soft for it's intended purpose.. and it's not easy to properly temper steel, each type has a specific temperature it has to be heated to, and then, you don't want it too hard, so it has to be properly tempered..
Just a note, sometimes those jacks will run out of fluid if you use them sideways. If you flip it over so that the pump is on the bottom, they will still work when sideways...
Aaron Z
Thanks for the tip, I didn't know that!! I will need a stronger jack for the other side, I'll start off with a 12 ton if it'll fit.
Yea, I wasn't using that hammer for the track pins, very awkward and hard to swing! My friend Ben (pictured above leaning over the bull gear) brought that one over, 2 swings with that thing, I said screw this and got my wood handled one! LOL.
I did not even think about swapping sprockets, but I will now! I didn't want to have 2 sides apart, but since it has been mentioned by a few, I will do it. I'm wondering if hiring out a mobile track/heavy equipment undercarriage mechanic to break track on the other side isn't out of the question? That wasn't easy! LOL
You got that right! this is my 1st tracked vehicle experience, Looks like I just might be rebuilding everything on this side and move onto the other.
Great idea!
You got it! I will swap the sprockets, now that I know how to do it!
Thank you, I will open up the other side, when I finish this side up, whenever that will be!
Thank you. I have a lot of cleaning to do!
I was concerned about all the heat I had to use on those links though...I'd rather hire that work out for someone with the proper tools.
Bull gear assembly pulled apart. few drops on a block of wood did the trick. isn't working in the dirt so fun!!
I'll order the bearings and seals from Zimmerman tomorrow, If he has 'em. maybe i'll start cleaning everything. I dunno
Maybe I'll start cleaning everything. Gonna take a lot of solvent/diesel/kerosene. I dunno, might need a break from this project. Where do I buy some motivation?
   / Doubt I can get this old Cletrac running... #119
mopardude, keep going! If we could assist you we would.:anyone:
Big project with a lot of grunting. Glad I'm two states away! :laughing:
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
UNUSED Hydraulic Skid Steer Mower Attachment (A47477)
UNUSED Hydraulic...
2020 Terex RL4 Towable Light Tower (A55787)
2020 Terex RL4...
2007 Cat 730 Haul Truck (RIDE AND DRIVE) (A50775)
2007 Cat 730 Haul...
