Homemade Kubota RTVX 1120Turbo Kit!
   / Homemade Kubota RTVX 1120Turbo Kit! #1
sharpnavy65
Great State of Texas...
2014 Kubota RTV-X1120D
Wanted to show some pictures of my Homemade GT15 Turbo Kubota RTVX 1120.
   / Homemade Kubota RTVX 1120Turbo Kit! #2
You’re about to live your life a quarter mile of grass at a time!
In all seriousness, that looks pretty nice. Any idea what the gains will be? How will you deal with engine management and tuning?
   / Homemade Kubota RTVX 1120Turbo Kit! #3
Really cool. Have you got to try it out much?
What did you set the waste gate at?
Youæ±*e about to live your life a quarter mile of grass at a time!
I removed one shim from the injection pump and maxed the injectors out. Running 10 psi boost. About to run a egt sensor to see the temp. Runs good. Not much faster on top end. Lots of torque now.
I'm around 10psi boost. It runs good. Sounds like a mini turbo Cummins. Top speed is not much faster. It has lots of torque now.
   / Homemade Kubota RTVX 1120Turbo Kit! #6
Because you don't want to over rev your engine, top speed should be about the same. But the time it takes to get there should be awesome!
you could probably crawl up a cliff if you could get traction.
   / Homemade Kubota RTVX 1120Turbo Kit! #7
Perhaps a dumb question, but is there something you could not do with your RTV before you upped the power?
I know with my BX tractor I spin the wheels well before running out of power. Upping the power would offer no benefit.
I get the MINE IS BIGGER THAN YOURS aspect...:thumbsup:
I go to rock crawling offroad parks. Wheeling up hill the kubota seems to bog factory. I also lifted it 2" and running 30" tires. It just needed that extra torque to climb. I won't have that problem now. Plus it sounds awesome too.
   / Homemade Kubota RTVX 1120Turbo Kit! #9
Makes sense that larger tires would require more power at the same speed as smaller diameter tires.
I can see clearly now...:D
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
Club Car Utility Cart (A55853)
Club Car Utility...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
