Good morning!!!!
   / Good morning!!!! #93,832
Another sunny day here. Got to go and get the sheep in before it gets too warm, the lambs need treating against fly strike.
Kyle I used to remove rust with electrolysis, but nowadays I find citric acid does the job quicker and cleaner. I think my plastic sheets were punctured by a sliver of steel (a genuine sliver - not like those slivers of cake you pigged out on at the weekend :) )
Ron, that's hard luck to get cut by soft plastic, hope it soon heals.
RNG, a tracked loader sounds interesting. Not sure how you are planning to do the cutting without a 3pt & PTO. Were you thinking of using the hydraulics to power a front mounted flail on skids ? Check if that requires additional cooling for the hydraulic circuit. Simply trailing a gas powered cutter could work, not sure about how awkward the turns for your slopes would be though.
   / Good morning!!!! #93,833
2019-05-14, 0340
33 right now...high about 50 and a mix of rain and snow(!!!) Jeez!
   / Good morning!!!! #93,834
RNG Case/NH use motor oil 10w30 for hydro oil, hydro fittings readily available, our tracks lasted four years and yes bucket can float
47 high of 66 today heat starts back tomorrow
Prayers for all
   / Good morning!!!! #93,835
38 °F and going to a high of 59 with 40% chance of showers. Wind NW 8 mph.
Yesterdays 49% chance of showers ended up being 100%. It pissed down rain all day.
Wow! It is warmer up here than at Roys' place. It must be that fresh Quebec air that is doing it.:D
There is not a lot on the books for today. Maybe dump some more fertilizer in the tree stump. Maybe sharpen lawn mower blades. May conserve energy.
Have a good day all
   / Good morning!!!! #93,836
33F snow rain mix now low 40's for high with more rain coming... good 1" snow on the ground now. :(
Not plan work outside this evening because of old man winter visit.
E muffin feed little critters slow roll to work.
Enjoy the day all.
   / Good morning!!!! #93,837
Poured first cup of coffee. 33° with clear skies and frost on grass this morning. Heading to 67° with mostly sunny skies. All I did yesterday was rest and walk out to mailbox and back. Finger feels much better today. Dentist appointment this morning. Then back to arranging things in the 2 barns.
The plastic I was cutting is King Starboard. Used on many boats today instead of teak, plywood and vinyl. I did 2 boat cockpit with it. Cuts and machines like wood. But never fades. Assembly with with screws. It's biggest problem is it will not glue reliably. I have lots of scrap pieces left over from boat and RV projects. I should have used band saw to make cut I needed. But miter saw was sitting next to my project and band saw is in shop. 70' feet away. :confused2:
Buckeye, glad you made it home safe and sons are ready to cut lawn.
Drew, bad time to travel. Maybe leave a day early and stay a day late.
Randy, change is hard for us older people. Hope your groundhog swallows its meds and stops digging holes. I found that there is usually more than one that you are seeing. Using the paint ball gun will help to check this out.
RNG, is a skid steer less likely to have roll over than a tractor? I know they are compact. If you need some info from a Skid Steer owner. I can send you Harvey's phone number.
Prayers for all.
Good Morning All.
   / Good morning!!!! #93,838
I'll have a LOT of questions for the NH dealer in town this week.
I hope they are experienced and that goes well. Good news is that machine sits low to the ground.
Bad news is it sits low to the ground for certain tasks. Just have to make sure the latter isn't your issue.
Sure would be for me, but entirely different application.
Have you looked at a Kubota?
   / Good morning!!!! #93,839
Kyle, hope you are feeling better each day. That's quite a shock to the system, heal well.
Roy, now I know where this cold air is coming from, cut it out will ya? Actually feels pretty good...
   / Good morning!!!! #93,840
Kyle, glad you got a good report with Dr visit. I got similar reports including biopsy of gallbladder. I hope you have good results like I did from removal.
Reel Mower (A55851)
Reel Mower (A55851)
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
Wood Gliding Chair (A53316)
Wood Gliding Chair...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2015 Freightliner Cascadia 125 Day Cab Truck, VIN # 3AKJGEBG5FSGD4138 (A54865)
2015 Freightliner...
2010 Nissan Frontier SE (A53314)
2010 Nissan...
