Thoughts on this CT122 with 68 hours
   / Thoughts on this CT122 with 68 hours #1
iptman
Gold Member
Northern VA
Scag Tiger Cat, 61", Kioti CX2510
Hey guys,
I found this CT122 with only 68 hours. They're trying to sell it with the snowblower but I'm trying to find out what their asking price is without. Any issues I should be concerned about? Problem getting parts? I assume most parts can be had through Kioti if not through Bobcat dealer. It looks virtually brand new. Thoughts on a fair price without the snowblower?
213 BOBCAT CT122 2WD TRACTOR 2674357 USED
   / Thoughts on this CT122 with 68 hours #2
I can't help you on price. I haven't had any problems with my CT230 that I didn't create from overuse/abuse. When I have managed to break things - Bobcat has always had parts one shipment away.
   / Thoughts on this CT122 with 68 hours #3
not much going on in this forum so thought I would respond I just purchased a ct445 and did a lot of research. Parts are not an issue as a matter of fact Bobcat is starting the tractor line up again this fall. If you look at the specs they seem to beat all the other specs of the similar size tractors. And while they are built at the Kioti Factory they do have different specs and different builds so they are not the same tractor. They are better.
The only real problem I see is everybody wants green and orange and consequently these tractors don't bring as much money which could be a bargain if you're buying or a sore spot if you're selling
   / Thoughts on this CT122 with 68 hours #4
I believe them to be good tractors, Very similar to Kioti for all the major things. Some differences in the wiring harness and loaders. That one looks like it has never had a rock in its bucket. Probably nothing harder than a little fluffy snow. :)
Here is Ted trying to tear one up with his new grapple on the front.
   / Thoughts on this CT122 with 68 hours #5
A different wire harness, seat and loader makes them better ??
Has Bobcat announced how long they're going to provide parts support for the CT series?
   / Thoughts on this CT122 with 68 hours #7
Now that Daedong and Doosan/Bobcat have signed new contract to supply tractors again parts availability until Daedong no longer supply parts for the same Kioti models.
   / Thoughts on this CT122 with 68 hours #8
Hey guys,
Parts are no problem through either Bobcat or kioti. This tractor is at a dealer only 20 miles from me, I saw it in person a couple days ago. I can stop in and take a closer look on tuesday if your interested in more info.
   / Thoughts on this CT122 with 68 hours #9
Bobcat gets parts quicker and does repairs much faster than my local tractor dealers. Don't worry about service. I would be a little hesitant because of the power of this model. I have heard that it is considered under powered.
They're not willing to separate right now, want $12,700 on a cash deal for the both. Plus I'd need to have it shipped so another $500-800. If I was closer and could go see it in person with a bank check in hand they might reconsider dropping the snow blower but as-is I'm going to pass. As a side note I'm anxiously awaiting Bobcat's return to the compact tractor market. Hopefully they white-label (ha) the CK2510 with an improved loader.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2012 Ram 5500 Service Truck, VIN # 3C7WDMDLXCG124340 (A54865)
2012 Ram 5500...
1969 Jeep 4x4 (A54865)
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
