May 6, 2019 / Question: M7060HDC12 Removal of FEL valve? #1 M mbu Silver Member Joined Jun 1, 2008 Messages 123 Location Colorado Tractor . On a Kubota M7060HDC12 I need to remove its FEL hydraulic control valve. Do I have to drain the tractor's hydraulic oil reserve to do this? Thanks in advance...
May 6, 2019 / Question: M7060HDC12 Removal of FEL valve? #2 ovrszd Epic Contributor Joined May 27, 2006 Messages 33,727 Location Missouri Tractor Kubota M9540, Ford 3910FWD, Ford 555A, JD2210 Is the valve below the oil level in the reservoir? I don't think it is but am not sure.
May 6, 2019 / Question: M7060HDC12 Removal of FEL valve? Thread Starter #3 OP M mbu Silver Member Joined Jun 1, 2008 Messages 123 Location Colorado Tractor . ovrszd said: Is the valve below the oil level in the reservoir? I don't think it is but am not sure. Click to expand... The return to tank line appears to be above the reservoir but the pump and power beyond ports are near the bottom of the tractor.
May 6, 2019 / Question: M7060HDC12 Removal of FEL valve? #4 ovrszd Epic Contributor Joined May 27, 2006 Messages 33,727 Location Missouri Tractor Kubota M9540, Ford 3910FWD, Ford 555A, JD2210 I added a 3rd function to my 9540 but I can't for the life of me remember if I had to drain the oil. Sorry.
May 7, 2019 / Question: M7060HDC12 Removal of FEL valve? #5 L Like Tractors Silver Member Joined Jul 15, 2018 Messages 168 Location Eastern Iowa Tractor Multiple Kubotas I added third function kit to my M7060HDC12 and didn't drain the system.
May 7, 2019 / Question: M7060HDC12 Removal of FEL valve? #6 ovrszd Epic Contributor Joined May 27, 2006 Messages 33,727 Location Missouri Tractor Kubota M9540, Ford 3910FWD, Ford 555A, JD2210 Like Tractors said: I added third function kit to my M7060HDC12 and didn't drain the system. Click to expand... There ya go. Sounds like you can remove the valves without issue.
