10W-30 HYD replacement or substitute
/ 10W-30 HYD replacement or substitute #1
XSKIER
Fenton, MI
'11 Deere 1026R
An exhaustive Google search did not turn up much, so I thought I'd pose this question to y'all. Can I use AW68 in this application 50F-90F?
25 year old WACKER roller
/ 10W-30 HYD replacement or substitute #2
You mean a replacement oil for a Hydraulic system hat was spec’d to take 10-30 engine oil?
Jd Hydrau or Hydrau XR is designed to be such a replacement. I use it in my skid loader.
Yes, wacker does specify 10W-30 in the hydraulic system. The term "engine-oil" is not in the spec, so there is where my confusion is. Do I use "oil" or "fluid"?
/ 10W-30 HYD replacement or substitute #5
There is no industry standard separating the terms. If Wacker specifies 10w-30 oil that means engine oil. This is a fairly common recommendation for hydraulic and hydrostatic systems NOT containing clutch packs or wet brakes.
/ 10W-30 HYD replacement or substitute #6
Because 10w30 is so hard to find?
No. The issue according to JD is that engine oil specs are constantly changing ( CI, CJ, CK, etc). Also, zinc and other anti wear additives are being reduced because of potential harm to emission systems. JD said that they had to test and re certify every time a new motor oil spec would come out.
So they came out with “Hydrau” . JD owns the spec so it won’t change, and they are able to put the amount of zinc in that they want.
/ 10W-30 HYD replacement or substitute #7
What does Deere have to do with a machine built by Wacker?
/ 10W-30 HYD replacement or substitute #8
They have an oil that is designed to be a replacement hydraulic oil for equipment that specifies 10w30 motor oil.
I read the WACKER spec again yesterday. Anti-Wear Hydraulic Fluid 10W-30 in the hydraulic system. API rated SAE 10W-30 in the Briggs 16hp, and SAE 10W-30 in the exciter box.
/ 10W-30 HYD replacement or substitute #10
Many of the popular hydraulic/transmission fluids are 10W-30 fluids.
/ 10W-30 HYD replacement or substitute #11
XSKIER--I know you have some JD hygard around. JD says that works in systems specified to take a 10w-30 AW hydraulic fluid.
/ 10W-30 HYD replacement or substitute #12
As I understand it engine oil and hydraulic fluids are same as to body (10w30 and such) the difference is in additives, engine oils have different additives than hydraulic fluids (oil) difference is wear factors and anti corrosion and what ever....
Found the specs for Hydrau. I have Hy-Gard low viscosity here, but that is like a 10 weight oil. My local dealer did not have any Hydrau in stock. I have decided that AW 68 should work ok for this application. I have the AW 32 Lube King in my Yale lift truck, and get good performance out of it. View attachment FAQ_Hydrau_HydrauXR.pdf 151166_1.jpg
(INOP) 2010 JCB 930 ROUGH TERRAIN FORKLIFT (A62129)
(INOP) 2010 JCB...
KUBOTA BX2380 TRACTOR (A62130)
KUBOTA BX2380...
2014 Keystone RV Outback Camper, VIN # 4YDT21027EB451241 (A61165)
2014 Keystone RV...
Aluminum Fifth Wheel Tripod (A61166)
Aluminum Fifth...
UNUSED WOLVERINE QMP1-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2016 Kubota SVL 95-2S Skid Steer (A61166)
2016 Kubota SVL...
