California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,588
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
When I bought the Yanmar YM240 in 2003 it was neglected with loose bolts everywhere. I reset the right side 3-point pivot pin - 'hinge" - with red (permanent) Threadlocker, noted the sloppy fit of the threads, then forgot about it. Years later the hinge pin fell out in 2017 taking out a small chunk of the axle housing. I bought and installed a new hinge pin from Hoye, this time setting it with J B Weld and using that to fill the missing chunk. That lasted 2 seasons using the backhoe to pull stumps, then the pin ripped out taking a larger chunk of the axle housing. 3-point backhoes are hard on tractors!
I inquired about a replacement axle housing assembly, complete, because I don't have the pullers or press to tear down the assembly. I was told $350 for a bare housing plus new seals etc. Or If I wanted the complete axle assembly, $350, then near $350 for truck shipping because, I was told, it was too heavy for UPS. Then another $350 to ship back my broken assembly or else a $300 core charge. So a $1,000 project. I balked at that.
Due to the cost I was facing, I decided to install a pin with deeper threads. The stock pin and its genuine replacement didn't go all the way to the bottom, so maybe threading in that extra 3/8" would prevent it from coming loose again. So I bought a pin intended for an implement and cut it to the length that would bottom in the hole. This pin has SAE threads which are a few thousandths larger OD. I got a bottoming tap, and set this longer pin in J B Weld, plus a lump of QuikSteel to fill the missing chunk. (J B Weld is to runny to fill a void).
Then ... Thinking about this some more I decided it would never work. I didn't put in service.
I called a Craigslist tractor salvage yard in Portland a thousand miles north of me and bought a YM240 right axle assembly. Since I don't have a hub puller or a big press, it was simpler to replace the entire axle assembly intact. This one was $350 for the complete assembly (plus $85 for FedEx) and no return shipping or core charge needed. The label when it arrived showed the complete assembly was only 37 lbs.
Installation was simple. I bought a HF crane ($100 with coupon) after I had been told the axle was so heavy it couldn't go by UPS, but then I didn't need it for the axle. The crane was a big help with the 100+ lb tire and especially for intricately snaking the 100+ lb ROPS back into its very tight fit. Aside from rasseling heavy objects, installing the axle assembly complete as a single module was simple. Note the PTO assembly has to come out to detach the inner end of the axle.
It's all back together, and I went and dug out a stump. Good for another couple of decades. This is the first serious repair this tractor has needed in 15+ years, not counting the aftermarket loader's hose etc.
The clean axle housing photo is the one I took off, showing the pin and filler I had installed on it then never used. Anybody need a replacement axle shaft or hub?
