Backhoe Starting issues
/ Starting issues #1
wisc
I was allowed to borrow a Kubota L-2800 from a relative. Very nice gesture!!
Tractor can only be started with a screw driver touching the starter solenoid and the battery wire to the starter. I thought it was possible a kill switch issue. However once it痴 started you can get off the tractor and it keeps running. I believe that means the kill switch is not the culprit. Any ideas?
/ Starting issues #2
The tractor's safety systems are much more complicated. At the heart is an OPERATOR PRESENCE CONTROLLER.
How do you stop it? Unless someone has bypassed a lot of stuff the engine stop solenoid should be kicking into action.
I have pulled some pages from the Workshop manual ( A Scottish version but likely quite similar).
Once you have read over this material ask more questions.
Dave M7040
  • Forum Pages from L2800, 3400 Workshop Manual.pdf
  • forum Pages from L2800, 3400 Workshop Manual 2.pdf
/ Starting issues #3
Replace the ignition switch?
I had to have the clutch in on my L2850 shuttle shift tractor.
/ Starting issues #4
You can cerify that it is the ignition switch by jumping the back of the switch.
/ Starting issues #5
I second the recommendation of farther testing before throwing parts at it. Follow through with what Dave say's in post 2,and go from there.
