Cleaned up and re-painted ol Bushhog....
   / Cleaned up and re-painted ol Bushhog.... #11
Yep , looks good ! Nothing like chain guard on them also instead of the rubber cheaper rock guard . IMO .
   / Cleaned up and re-painted ol Bushhog.... #12
Tractor Supply enamel.. I’m not 100% but I think it was IH Red.. (read somewhere it was a close match too Bush hog)
No hardener.. Im a novice.. Just a little thinner with the paint ran thru a cheap gravity fed paint gun..(home depot $50)
What does the hardener get you?
Mixed in exact proportions, to the right paint, it helps it dry faster and is a bit harder when dry. Only use it when mfg's state how to use it.
Yes.. My Deere 709 had rubber belting and I would always pucker when I heard sticks/rocks hitting the back of tractor, just thinking my glass was about to shatter. With chain, I don’t hear anything hitting the back of the tractor anymore.. Another thing Mfg’s should be forced to install for safety...
Sounds a bit too precise for me.. I’ll have to research it more next time..
   / Cleaned up and re-painted ol Bushhog.... #15
And you'll have to wear a resperator hardner is very toxic.:thumbdown::drink:
   / Cleaned up and re-painted ol Bushhog.... #16
looks good. I need to have some plate metal, cut fit and then repaint ours.
I used to live in Seabrook. Off of Repsdorph rd back in very early eighties.
Yep - as a former Friendswood, TX/La Porte/ South Houston resident, we both know how fast a new paint job will turn to rust right before your eyes. Cavjock22 best keep a good supply of that red paint handy. Inside dry storage is the only preventative that I know of.
Luckily my gear is in south texas.. But your correct.. If it was here, It would be a full time job keeping it looking good...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
Electric Golf Cart (A56859)
Electric Golf Cart...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
Utility Tilt Trailer (A55787)
Utility Tilt...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
