B2650 I picked her up todsy
   / B2650 I picked her up todsy #1
LeeL
Member
Winter Springs, FL looking to retire in Lake Placi
Kubota B2650
After looking and with a lot of advice from this forum I went with the 2650. Tomorrow I'll put her to work. 20190426_132002.jpeg20190426_131947.jpeg20190426_131934.jpeg
   / B2650 I picked her up todsy #2
Congrats! Making me anxious to make my order for one.
Curious, what length is that trailer?
   / B2650 I picked her up todsy #6
Congrats on the new tractor!!!! Anxious to hear how you like it as you put some hours on it.
Kathy and I put 7.7 hours on the tractor herb first day. I am very impressed with her performance and ability using the brush hog. She ate some pallmetto bushes and 1.5 inch saplings with no problems.
I am very glad that we went with the 2650 in lieu of the 2601 with the wider and bigger stance and 60" implements over the 48"
My only con to the tractor is the lever for the FEL is a little too close to my thigh and when I shift my body to look behind me my thigh moves the FEL.25640.jpeg25625.jpegIMG_0505.jpeg25624.jpeg
   / B2650 I picked her up todsy #8
My only con to the tractor is the lever for the FEL is a little too close to my thigh and when I shift my body to look behind me my thigh moves the FEL.View attachment 602448View attachment 602449View attachment 602450View attachment 602451
Use the loader lock in position lever to prevent the moment of the loader when you accidentally bump the lever.
   / B2650 I picked her up todsy #9
On some open field mowing and depending on how bumpy the soil might be a tractor mowing sometimes is smoother riding with the weight of the front bucket off the tractor. Try it both ways and choose the smoothest ride quality.
   / B2650 I picked her up todsy #10
When I had my b2620 I needed the FEL on it when using a bushhog due to the front end being light. Put weights on the front and it solved the problem. Is that the case on the B2650 or does the B2650 have enough weight to handle the bush hog.
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
