Dozer ID
/ Dozer ID #1
musselmark
grand tracadie PE
'05 NH TN75DA
Can anyone tell me what type of dozer this is from 1970s. Is it capable of getting stumps out. Its for ssle locally for 2500 and apparently starts right up.
/ Dozer ID #2
A picture would help but I’m guessing it’s a worn out money pit.
/ Dozer ID #3
Any dozer for $2500 is scrap price. I wouldn’t expect much.
/ Dozer ID
Sorry I sent the question before figuring out how to attach picture. I still cant figure out how to attach it. Ad says it starts right up and runs great. How do I attach a pic
/ Dozer ID
Here is pic. Gas engine everything in working order. He ssid ot weighs 1 ton.
/ Dozer ID #6
Maybe if you want to push out saplings but useless for big stumps. And it’s going to be constant headache. It looks like one track is already rolled off.
/ Dozer ID #7
Run, run away. I wouldn't want anything smaller than. A 550 jd for stumps which would be around 18-20klbs. Actually for straight stumping I think a track loader would work better.
/ Dozer ID #8
Definitely not a good machine for stump removal. IMHO it's not worth anything close to $2500. I'd keep looking.
/ Dozer ID #9
Also the undercarriage could be worn badly :eek:.
/ Dozer ID #10
Definitely agree. After purchasing a JD 350B dozer, I found that to be too light for pushing out stumps of an size to them. Sold it after a couple of years. If I ever bought another, I would go with nothing less than a JD 450 or another brand in the same weight class or heavier.
What you are looking at, if in reasonable shape, would be ok for dressing up old logging trails or similar work, not for cutting new ones. Nothing heavy duty.
For $2500, I would consider it. Some 3-point hitch back blades cost more than that. But keep in mind what are the chances of parts availability. The grousers still have plenty of wear left on them. Could be the track adjusters need some attention.
/ Dozer ID #11
An excavator would be a much better tool for removing stumps than a bulldozer.
/ Dozer ID #12
The track is off the drive sprocket, the sprocket is junk, the chains are probably junk. If the idiot selling it said it is in operating condition he is a liar. It surely weighs more than a ton. Figure the value at $13 per ton delivered to the closest scrapyard. There is nothing but expense and aggravation there.
/ Dozer ID #13
Looks like my oliver, maybe an oc4
My oc3 is a fun machine but stump digging size
/ Dozer ID #15
I own a Case 1550 dozer. It's 170hp and weighs 40,000 pounds. If my soil is wet, as it is in Spring, I can pop 12 to 18 inch pines out of the ground fairly easily. If the soil is dry and hard, I struggle getting 6 inch stumps out of the ground. Stumps are ten times harder to get out then full sized trees. I also tear up the ground something crazy, and it usually takes more time to fix all the damage the ground then it takes to get the tree out. I've learned that it is faster and easier to just dig the entire tree out with my backhoe. An excavator would be even better at digging out trees or stumps.
With all equipment, HP is what you need to look at first. I learned on a 80 hp John Deere 450G that was fun and easy to operate, but too light for clearing the land. It's great for building house pads and spreading materials, but if the ground is hard, it's not very good at digging. My backhoe is 80 hp and I can take out any sized tree with it. Biggest have been close to four feet thick at the trunk. Pines are about the hardest to get out because of how deep their pat root runs. I would think that an 8 tonne excavator would be close to the same in digging ability as my full sized backhoe, but better because it's on tracks and it can spin 360 degrees.
The dozer in your picture would be fun as a toy, maybe most some light material with it, but never to be relied on to do any work.
/ Dozer ID #16
a CAT D10 would have those trees down much faster than an excavator!.. so, I don't think so!.. I've seen a LOT of land cleared in my area, and Bulldozers are used, for Pines and Oaks!..
/ Dozer ID #17
I’m sure there quite a few 180,000 lb D10’s pushing out trees on Long Island.
/ Dozer ID #18
A modest sized excavator would have that job done before you ever got permits to move the D10 plus the time and crane bill to remove and reattach the blade. But if you want to play captain ridiculous I’m putting my money on a Cat 385 excavator for knocking over and burning the bush.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
John Deere 4520 (A60462)
John Deere 4520...
2022 EZ-GO ELITE...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
3pt 5-Shank Subsoiler (A64127)
3pt 5-Shank...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
