John Deere 2320 Power Beyond
/ John Deere 2320 Power Beyond #1
ruko
Stacy, MN
None
Hello
I'm sure this has been discussed numerous times on this forum but I can't find it. I want to install a power beyond for my tractor. Deere wants over 500 dollars for a kit. Just the kit, install is more. Just a simple hydraulic outlet and return for a small back hoe. Any ideas for a less costly alternative?
Thanks.
/ John Deere 2320 Power Beyond #2
You can do it yourself, you will need the hoses, fittings, QD's, and the "plug" (#23) that goes into the SCV spacer block. The JD part number is BLV10381 for the entire kit, and is closer to $400 at many places, not over $500.
This thread has some details on the parts, it's the same as your 2320 needs even though it's about a 2520.
https://www.tractorbynet.com/forums/hydraulics/100228-adding-power-beyond-3-spool.html
REAR AUXILIARY HYDRAULIC KIT
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 CH16579 Tie Band 3
2 M808059 Hose 2
3 LVA803382 Elbow Fitting 1
4 AM105466 Hyd. Quick-Connect Coupler 1
5 M42702 Snap Ring 1
6 AM105467 Hydr. Quick Coupler Plug 1
7 LVA803353 Bracket 1 (SUB FOR LVU802956 OR LVU802012)
8 24M7051 Washer 1 21 X 37 X 3 mm
9 M808314 Nut 1
10 LVU27130 Label 1 SUB FOR M808060
11 R26375 O-Ring 1
12 AM105465 Hydraulic Hose 1
13 T77857 O-Ring 1
14 14M7274 Nut 2 M10
15 LVU800471 Screw With Washer 2 M10 X 30, (USE WITH LVU802956)
16 M808273 Fitting 1
17 R44302 Tie Band 2
18 M809071 Fitting 1
19 M808055 Fitting 2
20 CH17260 O-Ring 1
21 M808034 Plug 1
22 M800633 O-Ring 1
23 PT13744 Plug 1
24 12M7066 Lock Washer 2 10 mm
Thank you.
/ John Deere 2320 Power Beyond #4
Hello
Thanks.
Do you have a loader? If so how many hoses on the loader valve, 6 or 7?
7 and your loader valve has power beyond perhaps feeding the 3 pt hitch.
Will your backhoe be mounted on the 3 pt hitch or on a sub frame?
Dave M7040
/ John Deere 2320 Power Beyond #5
Dave M7040
The loader valves are attached directly to the tranny case and most of the JD sCUT and CUT machines, so there are no hoses feeding them like on remotely mounted valves.
Have a loader with 4 hoses to it. I would like to mount it on the 3 point but I understand this can be a problem due to the weight. Looking for a light duty hoe that is comparatively light. Some of the adds I see are claiming you don't need a sub frame with their units.
Thanks
/ John Deere 2320 Power Beyond #7
The backhoe company doesn't have to pay for repairs if their 3pt backhoe damages your tractor. It's not the weight of the backhoe that is the problem, it's the forces that the backhoe puts on the hitch. The 3pt hitch is designed to pull implements through the ground and to lift implements up. It's not designed for implements that can lift up the tractor or push on it with thousands of pounds of force.
I've not seen any 'light duty' 3pt BHs that have significantly less digging force than the official manufacturer ones. If they did they'd be lacking digging ability.
Messicks did a video on 3pt backhoes a while back. They said they see a few machines a year that have been damaged by 3pt backhoes.
If you get a 3pt backhoe anyhow, make sure it has braces from the lower 3pt arms to the upper one that replaces the top link. The braces prevent the backhoe from pushing the 3pt linkage up and possibly hurting the operator.
I got a used Branson (actually made by Ansung) backhoe from my dealer, with the subframe for my tractor. It cost less than most of the Chinese 3pt backhoes.
/ John Deere 2320 Power Beyond #8
The 2320 has an aluminum tranny case, you don't want to mount a 3PH hoe to that!
New/Unused Landhonor 78in Quick Attach Rock Bucket (A61166)
New/Unused...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2013 International WorkStar 7400 4x4 Altec AM55E 56ft. Bucket Truck (A61568)
2013 International...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
UNUSED SDLANCH SLDL25 CRAWLER DUMPER (A62130)
UNUSED SDLANCH...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
