Buying Advice FIRST TIME BUYER LOOKING AT USED KIOTI
   / FIRST TIME BUYER LOOKING AT USED KIOTI
Also have a 2011 Kubota BX2660 with a loader near me with 1000 hours for $8999. I've considered putting the 5k down on that and just financing the rest.
   / FIRST TIME BUYER LOOKING AT USED KIOTI #12
Around here 70 year old Ford 8N’s bring $2000-3000. I think that Kioti with diesel, 4WD, loader, plus a bush hog is worth $5K.
   / FIRST TIME BUYER LOOKING AT USED KIOTI #13
Plan on buying a new rear rim if you can get one. Tires are probably loaded with Calcium and the tube has a leak. Looks like the owner has already replaced one rim but the other one is going to need it as well.
   / FIRST TIME BUYER LOOKING AT USED KIOTI #14
That tractor surroundings tell the story how well it was maintained.I would pass at $5,000
^^^^^ What he said +++++
   / FIRST TIME BUYER LOOKING AT USED KIOTI #15
That would certainly seem to make a LOT of sense!
   / FIRST TIME BUYER LOOKING AT USED KIOTI #16
Asking $5k, will probably take $4500, seems like a pretty reasonable price. If it starts up, doesn't smoke, whine, or rattle, has power steering, I would take it. Not sure what distance you have to go, but you could travel a lot and not see better. If you can drive it, only takes a few minutes to test the clutch, gears, and brush hog. Personally, I don't leave my equipment outside, but maybe this owner does not have enough inside storage space. In this case, it is very important to drain ALL fluids asap, before putting it to extended use. I have taken a chance over a dozen times with older, neglected tractors and never regretted it. And never had to buy a dealer part. Good luck.
Thank you for your reply. I think I'm were you are, I'm gonna take a shot on an old machine and hope for the best.
   / FIRST TIME BUYER LOOKING AT USED KIOTI #19
I'm sure you're all biting your nails wondering how it went. I ended up passing on the tractor, it had a lot of little things wrong, and some bigger things. I'm still looking, thanks for the advice.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
2021 CHEVROLET 4500HD 16FT BOX TRUCK (A58018)
2021 CHEVROLET...
CATERPILLAR 305CR EXCAVATOR (A52709)
CATERPILLAR 305CR...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
