PTO blowing fuse
/ PTO blowing fuse #1
GeorgeW
East Texas
Kioti DK-45
After hitting a stump with the brush hog, the PTO on my DK 45 quit. Found a blown fuse, but upon replacement the fuse blows after 2-3 seconds when the PTO is turned on. Any ideas what to check and where to look?
Thanks in advance.
George
/ PTO blowing fuse #2
Could be a short in the solenoid, Continuity/resistance check is a simple troubleshoot check box. Depending on what dk45 you've got, the solenoid is back by the stbd hydraulic filter, next to the 4wd solenoid. Have a close look at the wires in the immediate area, could be broken/touching too.
/ PTO blowing fuse #3
Sounds like the blade is bound up to me.
Check if the disc that the blade is attached to will spin freely.
/ PTO blowing fuse
Thanks for the suggestions. The DK 45 is a 2003 gear model. Brush hog is not bound up and was disconnected when fuse was replaced. Visual inspection of wires seemed ok. Am not sure where the solenoid is located but will look where you suggested.
Thanks again.
/ PTO blowing fuse #5
Find the PTO solenoid and disconnect it. There should be an inline connector near ( a few inches from) the solenoid. Then see if a new fuse blows. If it does you have a short in the wires. If not you need a solenoid.
/ PTO blowing fuse
Finally got a chance to troubleshoot this problem. Found a frayed wired on the solenoid pigtail and was cautiously encouraged. Isolated the wire and turned the PTO on. Ran it for a couple of minutes, shut it off and then back on. Fuse blew in a couple seconds. Next took the fender switch apart, cleaned it and tried again, this time with just the ignition on, engine not running. Everything good. Turned PTO off with the the dash switch and then back on. Fuse blew in a couple of seconds. Next disconnected the solenoid pigtail. All good. Reconnected solenoid and same thing happened. Seemed good until turned off then back on. So, pretty sure it's the solenoid. Anything else I should do to confirm this?
Looks like there are four allen head screws that hold it on. Anyone ever replaced one of these? Any tips would be appreciated. Also, is dealer the only place to get one? Or, is there a good source elsewhere?
Thanks for any info and the suggestions you all have given so far. They were very helpful.
/ PTO blowing fuse #7
First, be sure the fuse holder contacts are clean. Poor (e.g. dirty, corroded) fuse contacts can generate enough heat to blow fuses prematurely. If you have (or can borrow) a DC ammeter with the right range it would be worthwhile to actually measure how much current the solenoid actually draws.
But I fear you will need to replace that solenoid, which is a $300+ part. There are also four (very cheap) O-rings under the solenoid; replace them too.
/ PTO blowing fuse #8
I am new to tractors so excuse the question... My first PTO attachment was a snowblower and the blower PTO shaft has a shear bolt built-in. Is this not standard on all PTO shafts. It sounds like the OP is facing an expensive repair rather than replacing a $2 shear bolt.
/ PTO blowing fuse
Yes, fuse contacts are clean. Don't have a way to check that much current, but a resistance check at the solenoid pigtail connector shows 5 ohms, almost a direct short.
The mower has a shear bolt. No matter how well one canvases a new area to mow, etc. many times an obstacle is missed. Have broken many bolts over the years. Guess this was one too many.
A web search did not turn up any sources for the solenoid, so guess this is a dealer only item.
Again, I appreciate all the help. It has been very useful.
/ PTO blowing fuse #11
The DK series tractors engage the PTO using a hydraulically-operated wet clutch pack (like an automatic transmission). The electric solenoid controls the hydraulic flow to the piston that engaged that clutch. There is no shear bolt or pin on the tractor; all of the PTO shafts and gears are inside the transmission with only the splined drive shaft exposed.
The CK tractor PTO design is more like the setup you describe.
/ PTO blowing fuse
This is a follow-up to this problem in hopes that it may be useful to someone else with an electrical problem. You can read the previous posts to see what was discussed. This picks up from there.
I discussed this with the mechanic at the dealer at some length. He concluded, based on all the tests that I had done, that it was most probably the solenoid, but would not commit to that without checking it himself. He also told me that he had never had a solenoid problem in his years at the dealership(he's been there a long time). He also told me that if I bought a solenoid and installed it, it would not be returnable since it was an electrical part(understandable). I decided to not take the tractor to him. A trip to take it and a trip to pick it up would be about 300 miles total. I could have the company that I work for pick up the part from the dealer and shuttle it to me at no cost to me for shipping. So, that is what I did.
When the solenoid arrived, I checked everything again. Everything was good up to the pigtail connector for the solenoid. Voltage was correct and fuse did not blow. Plugged old solenoid back up before removing it and fuse blew. Installed new solenoid, installed new fuse, and checked voltage again before plugging in the new solenoid. All good. Plugged in new solenoid, turned PTO on and fuse blew. NOW WHAT? What did I miss?
Ritcheyvs had suggested making sure the fuse contacts were clean, which I did. There are three switches in the circuit for the PTO, one on the dash, one on the fender and one on the lift lever to shut the PTO off when in automatic mode. Each of these switches have a pigtail connector. I had not checked them. Even though they were all very tight, I disconnected them, cleaned them as best I could and plugged them back up. Put a new fuse in, turned the PTO on and everything was GOOD.
Conclusions:
Check EVERYTHING in the circuit that you are having a problem with. I assumed that since the voltage was correct at the solenoid pigtail, that all was ok to that point. But that was with no load. It was failing with a load and I did not have a way to check it there with a load. Don't ASSUME anything.
I can only speculate that when the mower hit the stump, the jarring effect on the tractor shifted one of the connectors a bit so that it was failing under load.
I still love my Kioti. This is the first real glitch in the 14 years that I have had it and most of that glitch was operator error. I probably still came out cheaper than if I had taken to the dealer, and maybe I learned something in the process.
Again, thanks to all who gave input and suggestions. I hope that this might help someone else sometime.
/ PTO blowing fuse #13
Conclusions:
Shorts, grounds, and poor connections can be a painstaking hunt sometimes, especially if the problem is intermittent. Have spent years, on and off, searching for some, where the ground was tucked away, only showing symptoms on brief occasions. We see a lot of this with poor battery connections here on the forum. Cables, connections look brand new, but rust under crimps, only having issues when warm, that sort of thing.
Great to see you’ve got her sorted
/ PTO blowing fuse #14
Now that you have a spare solenoid you could disassemble it and find a manufacture or number on the coil :laughing:
As usually it is the coil that does fail on a solenoid not the plunger, many times a replacement coil can be located for much less then a new solenoid.
/ PTO blowing fuse #15
George, Maybe it's fixed and maybe not. A "dirty" fuse holder can cause a fuse to blow below the rated current as explained by Radio. Dirty connections for any of those switches should not cause a fuse to blow unless current leaks to ground, which is possible especially if wet and muddy. I obviously was wrong when concluded the solenoid was bad. If the problem returns, I recommend you get an ammeter and the schematic so you can isolate the issue with high confidence. You don't need to spend a lot of money on an ammeter as long as it has a 10 amp scale. This problem turned out to be a bit too subtle for the trial-and-error approach. You may have another chafed wire somewhere that got un-shorted (temporarily?) when you were moving wires to check those connectors. There is also a safety relay (to prevent starting with PTO engaged) that could be a factor.
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
Gas Powered Air Compressor (A66408)
Gas Powered Air...
Electric Transfer Pump w/Tank (A64127)
Electric Transfer...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
