Kubota L2350 will not turn over
   / Kubota L2350 will not turn over #1
apis4666
Kobuta L2350
My L2350 will not turn over.
   / Kubota L2350 will not turn over #2
Have you checked the following:
*You are in Neutral and the PTO is off.
*Make sure the HST treadle is not being pressed in either direction and it has returned.
*Bring the battery to an auto parts store and have it load tested.
*Check all fuses, use a digital multimeter if you aren't sure and check continuity.
*Check all wiring to make sure nothing is disconnected, cut, or torn up (check for squirrel, chipmunk, mouse, or rat infestations).
*Check the ignition key switch for proper operation using a meter.
I'm betting on a dead battery or a lever that isn't in the correct position.
   / Kubota L2350 will not turn over #3
My L2250 won't turn over unless the clutch is fully depressed.
   / Kubota L2350 will not turn over #4
Make sure the safety switch under the seat is not the issue. Once mine failed to turn over and simply raising and lowering the seat was all that was needed.
   / Kubota L2350 will not turn over #5
Your tractor is a very simple one when it comes to safety and starting.
If there is the presence of electrical power, i.e. lights working, then likely it involves this one safety switch.
There is only one safety switch involved, no complicated Operator Presence Controller.
Dave M7040
11' x 19' All Metal Carport (New/Unused) (A59225)
11' x 19' All...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
Enclosed Trailer (A56859)
Enclosed Trailer...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
