Just picked up a Bobcat S185 ....
   / Just picked up a Bobcat S185 .... #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
Planned on getting a set of OTT tracks to use in real muddy conditions as well as out in the woods.
Has anyone had any experience with TracksPlus Steel Skid-Steer Tracks ? They are listed at Northern Tool as well as my local JD dealer.
I will not be using these all of the time so I don't want to break the bank on a $4k - $5k set of tracks.
Primary use of the Bobcat for the next year will be supporting the construction of my new house.
   / Just picked up a Bobcat S185 .... #2
I just use tire chains. Mud and low c/g dont work well, you’ll quickly learn that its tough to get unstuck when it bottoms out :p
I just use tire chains. Mud and low c/g dont work well, you値l quickly learn that its tough to get unstuck when it bottoms out :p
I have use tracked bobcat's before and they have got me through everywhere I tried to go. I need a wheel loader because I have a mile and a half of road to keep up and tracks would wear out too quickly.
I was thinking OT tracks would work better than chains in the soft ground, just putting them on when I need to. Lighter footprint on the soft ground and yet 20 min to take them off for normal work.
   / Just picked up a Bobcat S185 .... #4
I have a Cat 246. It's a tire machine from the factory and after getting stuck numerous times in the mud, then the snow. I looked into O.T.T or chains. .. then settled on a complete bolt on track system made by Loegering. .. have never. ..ever gotten stuck again. It completely transformed the stability and capability of the machine. I can't imagine going back to tires.
   / Just picked up a Bobcat S185 .... #5
I've run Grouser brand tracks for the past 20 years, if you're in clay soils you'll never take them off. Grouser Products, Inc.
They have a pretty wide distribution network as most all of the SS brands sell them or can get them.
(I'd love to have a set of ^^^^ Tomtint's tracks, but last I checked they were over $11k for my machine)
Now those Loegering tracks are impressive (and so is the price) .....
   / Just picked up a Bobcat S185 .... #7
I’ve got a set of steel McClaren tracks for my Machine I put them one when them I’ve told if run the tracks on rubber tires machine that hard your drive motor pumps that why I only use mine when to muddy or if I’m on real soft ground I can usually put mine in about 30 minutes to a hour
   / Just picked up a Bobcat S185 .... #8
I find used tracks on Craigslist or Facebook market place they’re usually priced reasonably
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
New Idea Manure Spreader (A50515)
New Idea Manure...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
