What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #451
I cleaned mine up today. We've had more rain the last 5 months than the last 5 years it seems, my yard is a mess. We had the big pine tree cut down, and to keep if off any lines, fences or buildings, it had to go in the garden spot. Which I turned, right before the rain started a few months ago. So it's soft, real soft. Like walk across it and lose your boots soft.....so working up that tree, trying to get to it and pull out the pieces to clean up has left the 3025 a muddy mess as well.
So sunshine for the last few days, and supposedly until next week. My truck got washed, as well as the tractor. Tomorrow I have another load of milllings coming, so that will have to be spread. We also got a package today from the Arbor Day foundation with 10 trees to plant, so that will be done tomorrow as well. But today, it was all about getting the mud off. Didn't take any pics because by the time I finished, it was time to get ready for church. Maybe I'll remember to get a pic of it clean before I mess it up again, LOL
Where'd everybody go? Too busy usin' to post about using?
Lesseee....
Towed a log splitter to another neighbor's to split a bunch of firewood.
Moved a bunch of dirt around to fill in mole holes that had washed out.
   / What did you do on or to your LS Tractor today? #453
Disassemble a pasture shade structure that came down in big winds recently.
Managed to do it all with tractor / grapple, never left my seat.
Posts and 2" x 6" deposited on burn pile. We'll take the 15' x 3' roofing material to metal recycler.
   / What did you do on or to your LS Tractor today? #454
Lesseee....
well yeah, LOL been so busy I haven't been posting much. Let me get some pics over to the computer and I'll catch up some
   / What did you do on or to your LS Tractor today? #455
ok a combination of getting busy, and the phone and PC not wanting to work together so I could copy pics over. Finally got most of them I think....so here goes. I mentioned the guy buying the big pine logs from me...
   / What did you do on or to your LS Tractor today? #456
I could go back the last few days and post up pics, but it's basically similar stuff to what I've posted before, but today!
ok, was on facebook market, always looking for something maybe to buy and flip/sell.....but I have been looking for a disk, and today I found a guy selling one for $350. I talked him down to $280... this is a 6' disk, 20 gang ( I think that's the term)....went and picked it up. Used his tractor, an old mahindra, to load it. Man it sure made me appreciate my new LS! I did play around with it right before dark, but didn't get any pics of it. It sure takes out the ruts I've left in the yard as wet as it's been. anyway, here it is...
Put the subsoiler on, sliced a few areas. Turned around and used the bucket edge to slice a bit of sod to use on some areas that need patching. Ground is soft and wet, so not a whole lot of push to skim sod.
Then went after the tiller, fought with it for a while to get it mounted. Went back down and diced the sliced areas I hope to plant some stuff in. Then chewed up another area of dirt piles and moved some of that to sunken areas that need filling.
   / What did you do on or to your LS Tractor today? #458
Added a switch for the 3rd function valve.
   / What did you do on or to your LS Tractor today? #460
What do you control with the 3rd function switch?
The power to the valve so it can't be activated accidentally. Normally I have the ends plunged in to each other but just encase I don't it wont activate and hold pressure on the ends.
LOT OF GALVINIZED Z BAR (A58374)
LOT OF GALVINIZED...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
2015 Peterbilt 348 VacCon Combination Sewer Jetter Vacuum Truck (A55973)
2015 Peterbilt 348...
2005 John Deere 330CL (A55272)
2005 John Deere...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
