x500 oil filter not matching owners manual?
   / x500 oil filter not matching owners manual? #1
kelticblonde
John Deere x500
Hey all,
I have a 2015 John Deere x500. Went to change the oil today and noticed something very strange. The salesmen looked up my tractor via his computer and my product ID number. He provided me the oil filter according to that information. It is the same oil filter that the owner's manual requires. Now the actual oil filter on the tractor is a different one. It's longer and skinnier. The salesman could not figure it out.
Any ideas?
   / x500 oil filter not matching owners manual? #2
No idea, but welcome to TBN.
   / x500 oil filter not matching owners manual? #3
Welcome! I suppose that it is possible that you have the skinnier filter. That is about the time of the change. The OEM Kawasaki for that is 49065-7010. If yours is the smaller , use this number or the Deere AM107423 The larger filter is 49065-7007 is essentially the same as the common Briggs and Kohler filters. AM125424 is the Deere number for the larger.
Thanks for the reply. Is it possible to have installed (at one point in time) the wrong filter?? I know the shorter and fatter filter does not have the same base, however is it still possible? Allow me to post a picture of the filter on the machine. I think it fits perfectly.
I am not sure how to upload an image. I apologize.
   / x500 oil filter not matching owners manual? #6
Another difference is the air filter. The narrow oil filter engine had the flat panel air filter. When I look in the aftermarket book, they show very little difference at the base and the mounting thread is 3/4 16 on both. A quick look at the JD maintenance kits show the ones with the wide oil filter and snorkel air cleaner above serial 180,001 .
   / x500 oil filter not matching owners manual? #7
BTW on the top of the reply box ,the icon which is the 3rd from the right will allow you to search for an image on your computer and insert it. Once you select the image, click on up load files. It is kind of strange as the upload files isn't a normal radio button.
I think I figured it out. While finally changing the oil, I went to get my oil pan and found an old filter. It was the fat one like the salesman said would be correct. At one point in time I must have accidentally put on the wrong oil filter. YIKES!!! Now I haven't noticed anything wrong with the mower, could I have possibly damaged the engine? I change the oil very frequently.
   / x500 oil filter not matching owners manual? #9
If you're not leaking oil anywhere you are probably fine.
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
John Deere 693 Corn Head (A50514)
John Deere 693...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
